diyAudio Sponsor
Old 7th October 2010, 02:17 AM   #1
tdmax is offline tdmax  Singapore
Default Help!!! My Audioromy FU29 amplifier was fried!
Hi Guys,
I am from Singapore and I really need help and advice on my fried audioromy Fu29 amp. The amp just got fried on its own last week.
And upon opening up the bottom plate, I saw 2 pieces of badly burned resistors.
Due to the resistors burned condition, I can't figure out the resistors value to get them replace. I really appreciate if some kind souls, having the same amp could open up the bottom casing and advice on the resistors color code and value, could help me out on this mess.
All help is greatly appreciated.
Old 7th October 2010, 03:53 AM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
If someone does find the value, you still need to determine why it failed in the first place.
That looks like a power supply board. Something pulled too much current downstream.
Old 7th October 2010, 06:06 PM   #3
The resistor which is bigger and higher in the picture is 1K and the lower one is 2K2. I have one of these amps which is also not working because the relay on this circuit board chatters and won't latch on but as The Gimp says you need to find the short-circuit or other cause of too much current.
Old 9th October 2010, 08:26 AM   #4
Thanks for the info. Will try out and see how it goes.
Old 9th October 2010, 02:54 PM   #5
Globulator's Avatar
The bigger resistor looks like the one that got overloaded, with that size and value it is probably a dropper resistor for the driver tubes.
So I would check the driver tubes (and electro capacitors) for a short.
Something on the amp failed first: and it wasn't those resistors IMO, so fix the fault first, then replace the resistors!
Old 9th October 2010, 05:02 PM   #6
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Are the Audioromy amps available in Singapore and if so, where ?
I looked for some last year when I was in Singapore and could not find them.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 9th October 2010, 08:28 PM   #7
piero7 is offline piero7  Italy
piero7's Avatar
here the schematic of the fu29 power supply
Old 10th October 2010, 10:56 AM   #8
Thanks very much for that Piero7. Do you have a diagram for the main amplifier? The only schematic I have seen does not have a negative bias supply. Presumably the -31V is applied to the 828 grids?
Old 10th October 2010, 08:46 PM   #9
piero7's Avatar
Yes the negative tension is for the GU29 grid
Old 10th October 2010, 10:56 PM   #10
Thank you very much indeed! Your diagram makes more sense than the original. And very nice anode connectors too : are they commercially available? Did you ever try QQV6-40s in place of the 829s? My FU29 sounded very nice with these valves until the amplifier gently stopped working.
Help!!! My Audioromy FU29 amplifier was fried! tdmax Tubes / Valves 0 7th October 2010 02:12 AM
Fu29 & e813cc piero7 Tubes / Valves 4 5th April 2010 11:10 AM
Audioromy 838 Amp Broke need help.. tgrier Tubes / Valves 8 19th March 2010 06:32 PM
Possibly Fried Alpine MRV-F352 5 channel Car Amplifier lickwid Car Audio 19 2nd March 2009 04:34 AM
Please help! I've fried my amplifier. SoundQuest Parts 20 27th September 2003 01:49 AM
Page generated in 0.13358 seconds (69.97% PHP - 30.03% MySQL) with 11 queries
