| diyAudio Sponsor | ||
Good evening, ladies and gentlemen, it's time once again to play Guess That Tube. In this week's edition, we're going to present a distortion spectrum of the Mystery Tube connected as a common cathode amplifier with no feedback. Compared to the fundamental's reference level (-15dB from full scale on the graph, 8.5V RMS output), second harmonic is about -70dB and dominates the 0.03% THD. Third and higher are below -100dB (0.001%). Several samples were tested with very similar results.
Can you Name That Tube?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#2 |
Volt/Ampere curves are needed for guessing.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
OK, here is my guess. It is based on the fact that you have posted about certain circuit in another thread that contains LED's, CCS's, and an uncommon tube. The tube would be a triode connected D3A?
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#4 |
George you are more courageous than I, I waffled and did not post my suspicions..
This seems like both a reasonable level of thd and output amplitude for a D3A with about 110mVrms of signal on its grid, CCS load and IR LED bias..
www.kta-hifi.net |
#5 |
I have no reputation as a tube guru, so I have nothing to loose by making a dumb guess
#6 |
8.5V RMS, is that the output or the input voltage? LED current is 8mA and 0.8mA. Is it a 12AT7 by any obscure chance?
#7 |
I've only recently learned a bit about tubes, so I've no reputation to loose... so here goes... is it a triode connected 7788 ???
#8 | ||||
Of course we know that SY and Pete are collaborating on a crossover network and an entirely new "mystery tube" might have been discovered. Quote:
#9 |
6P1P in triode?
Whatever it is, its a beam power tube strapped as a triode. Last edited by kenpeter; 12th April 2010 at 01:18 AM. |
#10 | |
Basically IR LED bias triode connected D3A loaded by a gyrator driving a passive EQ into a fixed biased 5842/417A also into a gyrator load.. Other than that IR LED there is no sand anywhere in the signal path.. That IR LED works far better than a RC bias network with any cap I could find, and saves some additional circuit complexity and another coupling cap in the path. It's been built by a few others mostly in Asia where it seems my few current fans all reside..
www.kta-hifi.net |
| Introductions I guess | anatech | Introductions | 8 | 2nd March 2009 04:06 AM |
| Guess, what is it? | Wavebourn | Everything Else | 12 | 20th October 2008 08:40 PM |
| I'm new here I guess | navinjohnson | Introductions | 3 | 25th September 2007 08:38 PM |
| i guess... | Mr. Triatic | Solid State | 1 | 22nd May 2002 07:33 PM |
| Page generated in 0.12282 seconds (82.58% PHP - 17.42% MySQL) with 11 queries |
