6SN7 equivalents in B9A
Old 5th June 2009, 06:53 PM   #11
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally posted by dsavitsk
If you haven't seen it, John Atwood has a nice writeup of history and types at http://www.6sn7.com/
The author writing that RCA and GE were pushing on the market miniature replacements probably don't know why: the government wanted smaller tubes for computers so invented a genuine trick: taxes of an enclosed vacuum.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 6th June 2009, 02:34 AM   #12
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
If you can find them in 8 volt heater version they are often cheaper too!......And if you have 12.6VAC available you can just use a rectifier diode in series with the heater
I have a big bag full of 8CG7's. I have found that if your amp uses a Hammond power transformer on typical US 122 to 124 volt power, your filament voltage is probably about 7 volts already. Just plug them in. Most of them work just fine.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 6th June 2009, 03:01 AM   #13
Wavebourn's Avatar
Nice trick: rectify 6.3V by a Shottky diodes' bridge, and get exactly 8V on 10,000 uF/10V filter cap under load. I used that in my Tower class A hybrid (2x200W) to power filaments of 8AL9 tubes.
Old 6th June 2009, 09:25 AM   #14
andyjevans is offline andyjevans  United Kingdom
Not sure why you'd not use a 6SN7. If it's cost, use the loctal 7N7 or 7AF7. The latter is handy since it has half the filament draw.
If it's size of socket, the rimlock ECC40 is a great sound. Pretty much 9A size.
Good 9A tubes around this spec include the E80CC which is vastly better than the ECC82
andy
Old 6th June 2009, 10:54 PM   #15
Tubologic is offline Tubologic  Belgium
Tubologic's Avatar
andy
... And vastly better than the venerable 6SN7. The E80CC is without any doubt the most linear and best sounding dual triode in 9A (noval) basing you may ever find. Originally designed for demanding (professional) audio applications,not a TV vertical deflection amplifier tube (like the 6CG7/6FQ7/12B4/6BL7/6BX7...) Designed by PHILIPS, the E80CC is a SQ (Special Quality) long life (10.000 hours) tube with gold pins,tight tolerances and excellent matching between the two triode elements. Hard to beat,even with the best 6SN7 variety (5692 Red Bases anyone ?) . Not a direct substitution for the 6SN7 but close enough, It can be used in most 6SN7 applications where plate voltage doesn't exceed 350V. A very underrated tube which can still be found cheap.
Old 6th June 2009, 11:03 PM   #16
Wavebourn's Avatar
ECC80 like 6N1P was designed to replace obsolete 6SN7 in a new gear, that means in similar applications it will exhibit similar linearity.
E80CC is a special version of ECC80, like 6N1P-EV
Old 6th June 2009, 11:15 PM   #17
KSTR is offline KSTR  Germany
KSTR's Avatar
JJ ECC99, mabye? (I'm not an expert on tube designs for HiFi)
- Klaus
Old 6th June 2009, 11:22 PM   #18
Tubologic's Avatar
There never was a ECC80 and consequently the E80CC is not a "special version ECC80". Also,it was not designed to replace "obsolete" 6SN7's but was intended for broadcast and industrial applications.
The (Russian) 6N1P is electrically similar,but as far as building quality and tolerances are concerned it can't be compared to a E80CC.
Old 7th June 2009, 12:06 AM   #19
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
E80CC cheap? Send me some.
Anyway the E80CC is a late Philips development intended for the professional user (instrumentation, studio, telephony, telegraphy etc) using boxed anodes and a pin to pin layout conform to the B9A standard.
It's a very linear, reasonably low mu, twin triode bigger than a 12BH7A that CAN be used as a drop in replacement for a ECC82.
It will sound different from the original ECC82 when used as a replacement for that valve but then it should.
Sure, it will often make that circuit sound better but it would be better still if the anode load and cathode resistors were to be adjusted to properly accomodate this valve.
While I can understand the enthusiasm for this E80CC (6085 to US users which were invariably sourced from Europe), it really shouldn't be considered as a drop in replacement for the humble (and mediocre) ECC82/12AU7-A.
And yes, more bad news, there was an ECC80 but it has nothing in common with either the ECC82 nor the E80CC....
Ciao,
Frank
Old 7th June 2009, 12:30 AM   #20
Wavebourn's Avatar
As I said, as soon as American government invented taxes on enclosed vacuum to force an industry to make smaller tubes for computers, octal tubes were considered as obsoleted all around the world, and miniature replacements were designed and offered. Among them, Philips offered ECC80 to replace 6SN7. SOviet engineers made 6N1P. Yes, tolerances of Russian manufacturing are out of question, I myself worked in a team that restored QC measurement equipment when a Ministry comission demanded from the head of the plant to restore it.
Tolerances of RCA tubes were incredible, even thouigh Telefunken was known as the flagman of tight tolerances.
Neither 6N1P, nor ECC80 are direct replacements for 6SN7; they were designed to replace them in new designs
6SN7 equivalents in B9AHide this!Advertise here!
6H30 equivalents woodturner-fran Tubes / Valves 7 20th October 2007 08:00 PM
6F1 and 6P2 Equivalents fmak Tubes / Valves 1 27th September 2005 05:17 AM
MJ15003/04 Equivalents milos_r Solid State 2 2nd April 2004 02:23 PM
Help with Equivalents DieterD Parts 2 1st October 2003 10:58 AM
EQUIVALENTS palesha Solid State 5 28th November 2001 03:07 PM
