#11 | |
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#12 | |
BTW, I agree with JC on his 10 points. But I still like tubes. They have such a nice glow, and they don't go phfft, if you abuse them for a bit. Don, Drifting further OT, and speaking of tubes, and something they might do that sand can't, did you ever get a chance to explore the DHT seasoning factor? Sheldon |
#13 |
OT, re: Sheldon
Everything (the parts) are sitting on the shelf for the DHT experiment, but I've been way too busy with some other major projects: 1) The toroid winder machine (what a pain trying to find all manner of little mechanical parts for it, I probably over-did it with spring suspension rollers for the toroid rotation supports), have to go get my lathe yet too. 2) I'm modding a Tek 576 curve tracer to do tube curves (increased the V step range to 250V to handle even screen grid drive), now I'm including Mu and gm curves via a HF grid signal injection and synchronous V or I detection at the plate. 3) One of the surplus venders has a switching supply card for sale that is cheap and easy to convert to HV (exposed toroid HF xfmr). So I'm tracing the circuitry out for that. 4) I just bought a used Jet-ski, Yamaha Waverunner. The trailer tongue is too short for my car (I have to back the car into the water to get it off), so another project there. B.O.A.T. = Break Out Another Thousand $ May be a while Don
Ohms Law V = I R |
#14 | |
Sheldon |
#15 |
Feel like burnin some todes with that contraption?
Maybe a little non-beam-forming g1=g2 action? |
#16 | ||
The woek to collect wasnt done by me. a member called Dimitri did a heluva job! Regarding symbiosis MOSFET + TUBES or even tubes + transistors I miss a lot anybody doing such projects. I am of this opinion, that sometimes tubes do a better job in a circuit .. with all that high voltage across and their different good parameters. And sometimes transistors does it better, from some angle seen. But too seldome do they meet - due to division into 2 camps: - nothing but tubes - nothing but transistors or IC:s This two separated clans - where nothing but clensed and fundamental thoughts count is very unfortunate ![]() Because I am sure there are such good things to find in the Hybrid Thinking. There are a few that are handy with BOTH. We have Wavebourn we have one other Sheldon (stokessd) at his home SDS Labs http://www.quadesl.com/ Profile: http://www.diyaudio.com/forums/membe...fo&userid=3901 and there are some others. SY, our moderator, I think knows BOTH worlds, too. Myself have only elementary knowledge in tubes. I could build a SET (single end triode). No problem. But a little angst I have. ..... Angst(german) = Anxiety = fear. ==== I have advocated Transistor+Tubes hybrid designs at a number of times here in forum: See for example: http://www.diyaudio.com/forums/showt...02#post1228902 Quote:
It pleases me to know I am not the only gentle man around here. your lineup
lineup |
#17 |
I just finished a Mosfet/Aikidio hybrid (Moskito) there is a thread here somewhere. Its the only SS project I've ever got to work... I like tubes mosetly because they seem, to me at least, to be more forgiving. The picture at the beginning of the thread made me drool though.
#18 |
Hey Michael,
Old thread I know, but was just curious about your project and A2 type tubes. Have you tried many other tubes in A2 or zero bias? Is the Meteor zero bias (sorry I have not checked myself). I am just curious if it's worth to try a tube like this versus another thoriated tungsten that is mostly in class A1 (211). It also makes sense to me to use a tube that will be in current production and perhaps Taylor would make this one. I don't think I'll ever do a 304TL because of how much heat it demands. Nice work though!! I am sure it's very snappy and scary good bass. ![]() Regards, -Michael Woods |
#19 | |
My current breadboard-in-progress (below) in this line of amps is using a high plate resistance triode (the 35tg) with local feedback to enable it to drive a readily available OPT. There is about +25V on the grid at idle. The pentode driver is loaded by the current through the feedback resistor. Michael |
#20 | |
![]() ![]() ![]() Okay to be fair I must have been thinking (how do they sound) and should have asked more explicitly
| capacitor coupled vs. direct coupled ouput | hugobross | Solid State | 11 | 21st January 2011 01:56 AM |
| 6sn7 direct coupled and transformer coupled | neazoi | Tubes / Valves | 3 | 23rd May 2008 03:30 PM |
| Power follower class A Mosfet DC coupled. | Mr. Steve | Solid State | 30 | 15th February 2006 06:04 PM |
| My first amp - a direct coupled 2A3 | Wardsweb | Tubes / Valves | 51 | 3rd August 2003 04:22 AM |
| Can someone explain parafeed & direct coupled & a.c. coupled? | mwmitchell | Tubes / Valves | 2 | 11th September 2002 01:10 PM |
