| diyAudio Sponsor | ||
I'm not a great tube freak so can anyone tell me the pros and cons of Cascoded tube front ends? So far I have noticed lower gain than some circuits and a tendency for negative waveform clip and lower noise.
I recently purchased and put together a Cascoded 6sn7 tube driver board for a Dynaco. I noticed a lack of life in addition to sounding just so so. Was this just a **** poor design or is this a common fault to be found with this circuit? SY? |
#2 |
Like a Pentode's screen, a cascode stops V1's control
grid from seeing intrinsic negative feedback from the other plate that drives the actual load. Like a Pentode, you can run a cascode in any number of ultralinear configurations. Or feedback directly to V1's grid as O.H.Shrade (of RCA fame) did in 1938. You have a lot of options to shape the curves to your personal liking. |
#3 |
frugal-phile(tm)
Cascode has poor PSSR so usually used with regulated PS.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
The remark about poor PSRR is SPOT ON.
Cascodes have a very high O/P impedance. The gain of a cascode is approx. = (lower element's gm) (net ZL). The 'SN7 is a superb tube, but its gm is (IMO) only marginally adequate for service in a cascode.
Eli D. |
#5 |
PSRR is near perfect, as long as you like the noise
reference common to B+ rather than ground. Fine if you intend to ultrapath your output stage cathode back to B+, then helps PSRR that the drive from the cascode is also common to B+. ------------------------------------------------------- But thats not the only way to abuse a cascode. Here we ultralinear a cascode to compute 2xMu, and then Mu follow. PSRR common to GND. The parallel 6dj8's merely a scheme to have intrinsic feedback of V2 correct microphonics of V1 and vice-versa. Probably A and B triodes of entirely different envelopes. No attemt to match. |
#6 | ||
* Higher gains. * Greatly reduced Cmiller CONS: * Worse PSRR -- Needs clean DC * Output swing is thin compared to Vpp * Hi-Z output -- needs to work into a Hi-Z, Low C load. Quote:
The cascoded front end I did was a cascoded LTP voltage amp/phase splitter. Of course, a balanced topology is going to get rid of lots of distortion that a SE won't. The cascoded LTP worked out just great, and made for a great sounding final project. |
#7 |
A cascode does not necessarily have to use the same device on top and bottom. You can use a lower Z tube at the base, and feed it a portion of B+ from a resistor to give it the desired op point.
The 6DJ8 is designed with cascode service in mind.
Be sure your foil hat has a good low impedance ground. |
#8 |
Darn skippy those devices don't have to be the same.
Course, the current behavior tends to be dominated by the lower device, and voltage behavior by the top. Unless you impose some feedback scheme that sais otherwise. |
#9 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#10 |
Schematic
| Pros and cons of eliminating the front baffle | xlr8 | Multi-Way | 4 | 9th June 2008 09:36 PM |
| pros/cons of a 845 VS 211 | jarthel | Tubes / Valves | 2 | 18th June 2007 12:57 PM |
| TL vs MLTL, pros and cons | Tomac | Multi-Way | 5 | 29th December 2004 12:55 PM |
| Filterless DAC - pros and cons? | mr_push_pull | Digital Source | 1 | 11th August 2004 02:56 PM |
| Pros and Cons of this technique? | G | Tubes / Valves | 35 | 23rd October 2003 05:37 PM |
| Page generated in 0.11641 seconds (78.71% PHP - 21.29% MySQL) with 11 queries |
