#41 |
Interior painting for BB wood preservative
#42 |
almost
one good thing about music ,when it hit you feel no pain. so hit me with music.
#43 |
Might want to run some braces in the center of the interior boards...
#44 |
i think there are,just diffecult to see because of the blackness
#45 |
mannnnn, im so gonna build me a couple of these, would slide right into the back of a dodge caravan!
Mouth up with a couple thousand wats of amp! BOOOOOOOOOOM! Scaring little old ladies!
System: Hitachi HT-320, HK 330a, Energy 3.1e speakers and xbox360, android phone headphone out for hirez FLAC playback. |
#46 | |
the braces are there you can see them on this photo
#47 |
Plaster and sanding......., TH_1819 dimensions are HxWxD (125cm x 58cm x 80cm) - 49,21 inch x 22,83 inch x 31,49 inch. Weight is 80kg or 176,6 lbs without the driver.
#48 |
That thing is a BEAST!!!
#49 |
Yes it is, 30 minutes ago just plug in for the first time and it is a BEAST!!!
#50 |
![]() ![]() cheers.
| Horn Build using a tapped horn as a frame?? | 3GGG | Multi-Way | 1 | 17th January 2012 11:52 PM |
| Dayton SD315-88 Tapped Horn Build | killa12222 | Subwoofers | 11 | 15th June 2011 05:46 PM |
| Volvotreter 20Hz Tapped Horn build (pics) | RadiantNRG | Subwoofers | 60 | 12th March 2011 07:18 PM |
| Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background | layertone | Subwoofers | 15 | 23rd January 2010 05:12 AM |
| Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background | layertone | Full Range | 2 | 23rd December 2009 12:51 AM |
