TH-18 Flat to 35hz! (Xoc1's design) - Page 79 - diyAudio
Old 3rd September 2012, 04:30 PM   #781
Djim is offline Djim  Netherlands
Hi Dan,
A 'Symmetric' TH can offer that and doesn't have a compliance volume. The disadvantage it ends in bigger cabs and more wood. Well, I guess you can't have it all...
Old 3rd September 2012, 04:34 PM   #782
tb46 is offline tb46  United States
Hi Djim,
You got ahead of me :-). A symmetrical TH can have a compliance volume.
Oliver
Old 3rd September 2012, 04:37 PM   #783
Hi Oliver,
I know it can have, but why waisting (?) your energy when you can have an optimum load from the horn. Or do you see a reason it would be improved with an impedance correction, like a compliance volume?
Old 3rd September 2012, 05:04 PM   #784
Hi Djim,
I found that some drivers don't like to have any L12 (Hornresp S1=S2 L12=.01cm), and others need a L12 section to smoothen the first big dip in the TH response. In your drawing (Post #783) you are showing short "stubs" left and right, so you would have to account for these. The other way is a throat chamber with a controlled opening that equals the throat cross-section.
This is only based on Hornresp simulations.
Oliver
Old 3rd September 2012, 05:14 PM   #785
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Most symmetrical TH have a narrow but tall throat that does not evenly load the cone. It's like holding a cone edge with two hands and flexing it.
Dan
Old 3rd September 2012, 05:18 PM   #786
Hi NEO Dan,
Yes, I have been guilty of drawing a few of those. I have now convinced myself, that going with a more "squarish" throat might be better, also, it might help to extend the first section from the throat all the way to the back of the enclosure, and then expand left and right from there. You could make the case that loading against a flat sheet might be a good way to go. Ultimately, we have to build and test.
Oliver
Old 3rd September 2012, 05:19 PM   #787
Hi Oliver,
The 'stubs' (don't know the word) as you call them are the S1-S2 section (compliance volume). The length of them is only important for the high end of the bandpass, the volume can lower the first system resonance slightly. Adding a chamber instead is indeed different and could be a solution for getting a smaller total volume but at cost of extra compression losses.
No need to worry ; it works in the real world…
Old 3rd September 2012, 05:37 PM   #788
Hi Djim,
I guess I was borrowing the term for a short waveguide section, which is called a "stub" (e.g.: 1/4 wave stub). Maybe you could alternately model this by integrating the total volume of the stubs/cone/chamber in front of the throat, and call it a throat chamber; particularly at the wavelength involved. It's nice to know that it "...works in the real world...".
Oliver
Old 3rd September 2012, 06:17 PM   #789
Hi Oliver,
Thanks, stub: 'short remaining end'
Old 4th September 2012, 09:14 AM   #790
Originally Posted by Samuel Jayaraj View Post
Thanks CRESCENDO for the quick response.
So what is the clipping power of the QSC PLX3402 into a 4 ohm load, according to the manual/technical specifications?
I was curious, so I checked a spare PLX3402 I have.
These tests were done under zero load (no speakers or speaker cable connected). I measured the resistance at the speaker terminals at the rear of the amp for some reason. It fluctuated between 5.2 and 7ohms. Maybe un-useful info, but thought I'd share anyway.
Clip limiter OFF
40 Hz test tone
Enough level to drive hard into clipping
109.7v
Clip limiter ON (how my cab was measured)
40 Hz test tone
Same setting as above
94.6v
So, we can clearly see my driver never saw anywhere close to the 2200W spec during testing. I didn't drive it that hard into the clip limit light either. Soon I'll test the output of my TH-18 with the broken in driver and hopefully my voltmeter will be able to record the voltage this time
*Note: I could drive more level to the amp to gain a little more voltage (~130dB with a 100Hz warble tone), but this is just to gauge the affect of the clip limiter. Driving the voltage harder than above would've pushed it further from testing conditions in question anyway.
18 inch labhorn design. mulletdude Subwoofers 30 16th November 2016 02:04 AM
Ciare 18 bass horn design soundhead Subwoofers 6 22nd September 2015 11:32 PM
2 18 bass design simpleacoustic Subwoofers 101 15th May 2011 09:22 AM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
Copyright ©1999-2017 diyAudio
