Spreadsheet for Folded Horn Layouts...
Old 4th December 2012, 01:46 AM   #101
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Originally Posted by Brian Steele View Post
I finally got a chance to look at this. Yep, it seems like an error. The height of the back panel was being calculated incorrectly. I did a quick fix (see attached), but came across another minor issue - when you enter dimensions, they're used as external dimensions rather than internal ones (so the external dimensions will be larger in each direction by 2*panel thickness).
I've decided to rewrite that section of the workbook anyway, and will upload the complete version when finished (a few weeks, as I'm converting it from a stepped to a continously expanding horn, and including some calculations for bracing).
You KNOW I didn't read this! I just clicked on the attachment.
Old 4th December 2012, 01:52 AM   #102
Brian Steele is offline Brian Steele  Grenada
Originally Posted by BP1Fanatic View Post
I know I'm being anal, but why is this TQWP not 825.8cm2 (16" x 8") thru the whole 304.80cm (10ft) pipe? Under Initial Parameters, h should = 81.28cm (8" x 4 x 2.54cm). Are those parameters internal or external?
Did you do the optimization routine? D should be 0, not 0.12.
I'm removing the optimization routine from the new version of the spreadsheet, because it leads to confusion. Instead the spreadsheet will spit out the equivalent S1 to S4 parameters for HornResp input.
www.diysubwoofers.org
Old 4th December 2012, 02:44 AM   #103
BP1Fanatic's Avatar
h 86.99cm = D -0.10
h 87.01cm = D 0.33
h 87.00cm = D 0.12 = blue TH!
h = 81.28cm = 8" x 4 folds x 2.54cm
w = 40.64cm = 16" x 2.54cm
d = 76.20cm = 2.5ft x 4 folds x 30.48cm(12" x 2.54cm)
Why do you prefer the right fold over the left fold?
Old 4th December 2012, 03:14 AM   #104
BP1Fanatic's Avatar
h 86.995 = D 0.01!
Old 4th December 2012, 03:19 AM   #105
BP1Fanatic's Avatar
h 86.9943 thru 86.9947 = D 0.00!
Old 8th June 2013, 03:12 PM   #106
Well, presenting a new spreadsheet - BOXPLAN-THAM. This spreadsheet allows you to optimize the layout a "THAM" style TH before cutting any wood. The spreadsheet gives you all the panel dimensions required. Basically you enter the parameters for the desired TH, then adjust the panel sizes until predicted result (in blue) is a close match for the "guide" curve.
Old 8th June 2013, 03:13 PM   #107
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
It will be interesting to try it out Brian.
Mark
www.kravchenko-audio.com
Old 10th June 2013, 06:47 AM   #108
vladimir is offline vladimir  Belgium
vladimir's Avatar
This one looks realy great.
Old 31st December 2013, 01:47 AM   #109
Default Spreadsheet for "SS15" type folds
I've attached a spreadsheet that I've put together to assist with designing the layout of THs using a folding technique that's similar to the "SS15" TH design. I used this spreadsheet to design and build a new TH that fits a bit better in my car's trunk and addressed any bugs I came across along the way, so it's pretty much bug-free at this point.
To use:
1. Enter the dimensions of the subwoofer driver in the "Driver Dimensions" table
2. Enter your preferred box dimensions in the "Box Dimensions" table. If you are countersinking the driver (which I strongly suggest for this type of build), use the "driver offset" box to enter how deep the driver is going to be embedded into the baffle. If you're going to mount it on top of the baffle, enter "0" for the driver offset.
3. The spreadsheet models a dual-expansion TH like the SS15. If you want the change in expansion to occur a bit earlier in the horn, enter "x" for the "S3 at 3rd fold" option.
4. Under the "HornResp" params section, enter starting values for S1, S5 and L12.
Now, under the "Horn Design" section, enter the thickness of each panel under the "P" column, then start fiddling around with the horn expansion options and the panel lengths (basically all of the options in blue text). Keep your eye on the "Horn Expansion" graph. Basically your goal is to end up with a horn expansion that is as smooth as possible. The spreadsheet will automatically calculate the parameters that you'll need to enter into HornResp to simulate your TH design. If you don't like the results, adjust the TH layout accordingly, following the process above.
As the process is an iterative one, it may take awhile to come up with something acceptable.
Some notes:
1. The spreadsheet uses the "Advanced Centerline" method to determine the length of the horn. The measured results of the built vs. simmed horn suggest that this method produces results that are accurate to within 3%.
2. The spreadsheet assumes butt-joints and square cuts for all panels. It also does not calculate the dimensions of any braces (I'll add that in a later version). If you want to make angled cuts and use a different joining technique, it shouldn't be that difficult to take the panel dimensions from the spreadsheet and adjust them accordingly. And you'll need to design your own braces.
3. I was a bit skeptical about using 0.5" (12mm) ply for building horns, but it seemed to work out Ok for this test build, with certain conditions, like using stringers to make sure that the ply doesn't end up splitting when screws are being driven into it!
4. From my observations after having built THs for the same driver using two folding techniques, I'd say that the "SS15"-type fold is superior to the THAM-type fold in terms of end results, but the THAM-type fold is easier to build. With the THAM-type fold, a lot of attention needs to be paid to the bracing at the S1 and S3 points to reduce panel flex - much more than in the case of the SS15-type fold. This panel flex can cause the response at the upper end of the TH's passband to sound muddy if it is not properly addressed.
Old 31st December 2013, 11:30 AM   #110
Mark Kravchenko
It does work!
And if in doubt you can cut the head off of a finishing nail and leave the pointed side out of the chuck in a drill. Use the nail as a small diameter drill bit to make a pilot hole. IT will definitely not split then.
Mark
Spreadsheet for Folded Horn Layouts...Hide this!Advertise here!
Folded horn length Don Snyder Subwoofers 3 1st May 2009 11:14 PM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 10:44 PM
Looking For Folded Horn Sub Plans nniwelt Subwoofers 16 29th August 2005 04:43 AM
Folded horn for Tannoy? panos29 Multi-Way 12 17th October 2003 08:59 AM
