#11 |
Certainly I did not use any smoke and mirrors in my attempt. I calculated the path length thru the middle of the bends - not at 0.7 of the bend width which would give a lower response. When I first tried to design a similar cabinet I ended up with a box 700 X 700 X 600 That seemed a better compromise, but would use too much timber for this challenge!
I think that J Bells original simple tapered TH will be hard to beat for its LF response. |
#12 | |
BTW -- leaving out the bottom panel and saying "just sit it on the floor" is cheating..... One last: The cube achieves 100db. 98db@40hz and 103db@120hz -- in marketing lingo thats 101db +-3db from 40-140hz. Last edited by jbell; 25th July 2010 at 11:38 PM. |
#13 |
the only way to know is to built it and measure, JBells cube measured about 5hz lower then the sim too.
#14 |
The form-factor (cube) doesn't really matter, it's the net volume you can come up with.
A 2' cube has at best about 180L net volume. In the past, I've built well braced 12mm Baltic Birch cabinets for subs. I didn't think 12mm was adequate. I think 15mm is adequate, but 18mm is better. Formica (Melamine) on 15mm about doubles the strength, but adds a lot of expense. I've got a nice Hornresp for the Eminence 4015LF that's ±1.5dB from 40hz~150hz, and 100dB at 50hz. But it's 205L, not 180L. If you remove the external inductor and its DCR, it gives an almost identical response to yours.
Candidates for the Darwin Award should not read this author. Last edited by djk; 26th July 2010 at 12:59 AM. |
#15 |
#16 |
I would like to see live FR and Impedance graphs with a correctly dimensioned cab drawing.
Like the two posted here, most of the time the HR sim is not what gets built. |
#17 |
Oliver:
jbell's set of four tapped horns I've been playing around with the fold you presented here, which I really like. If I can increase s2 some, that'll help down low... and then see if I can get it out of a single sheet of ply.... |
#18 |
Any progress with this?
#19 | |
I, for one, make every attempt to follow the HR sim. Of course I use CONICs and build Parabolics, but the error is small, and I know I'm off a few percent in the corners. When I can't follow the HR sim, I go back and update the sim with the as-built information. If the damage is too bad, I scrap the drawing. Sims are sims, they are one dimensional equations simming a three dimensional world. We're lucky they even come close.
Don |
#20 |
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
| Page generated in 0.09343 seconds (72.18% PHP - 27.82% MySQL) with 11 queries |
