Does anybody have the plans for building a
Manifold 2 x 18 cabinet? as I want to Build this as my Next Speaker Project but I cant find the Dimensions anywhere I've head this cabinet and was quite impressed so if anyone has the plans pls share Here is the pictures of it http://www.speakerstore.nl/index.php...pg=12&prjID=56 http://www.speakerstore.nl/index.php?l=en&pg=12&prjID=6 Cant Wait.... Thanks in Advance |
#2 |
#3 |
What drivers do you have available?
Unless you use the original drivers, the plan is worthless. You don't need a plan to build these. All you need do is put the two baffle boards far enough apart to allow for mounting clearance. Figure out the back volume and the port size required for your drivers. That determines all the other dimensions.
Candidates for the Darwin Award should not read this author. |
#4 |
Thanks Much Apreciated!!!
I have EV EVX 180, BeymaLX60, and RCF L18 P540 Thanks Much Aprecited!!! Going to Start On These Cabinets.... |
#5 |
no problemo mate
#6 |
The original EV design is a 6th order equalized alignment.
A 2 cu ft 2nd order sealed box with an F3 of 30hz can only be 0.18% efficient (84.55dB). A 2 cu ft 4th order vented box with an F3 of 30hz can only be 0.36% efficient (87.56dB). A 2 cu ft 6th order vented box with an F3 of 30hz can only be 0.90% efficient (91.54dB). As we can see, the 6th order alignment is about 7dB more efficient than a sealed box, and 4dB more than a simple ported box. 0.312 is the optimum Qts for 6th order for box size vs efficiency vs bass extension. If you can give me the T/S parameters on the drivers you're considering I can give you an idea of what can be done with them.
#7 |
Thanks Will lookm em up and give you
#8 |
are those vented boxes? just lot's of wasted volume for the two drivers in the middle, but it does protect them if you are on the road.
regards Andrew T. |
#9 |
you can have a search on this site, keep us posted dj marvellous http://www.thielesmall.com/database.asp
regards, audiomachines |
#10 |
will look em up when I get home today and post them
Thanks for all the Help Will keep you posted... |
| eaw cabinet plans | Socaflex | Multi-Way | 25 | 10th February 2012 09:40 PM |
| AN-E cabinet plans... | cypher | Multi-Way | 14 | 27th June 2007 08:06 PM |
| BLH Cabinet plans | fin1bxn | Full Range | 3 | 27th June 2006 04:03 PM |
| Tempo cabinet plans | rebojorge | Multi-Way | 5 | 6th July 2004 11:36 PM |
| Page generated in 0.11283 seconds (80.46% PHP - 19.54% MySQL) with 11 queries |
