Old 16th November 2011, 05:18 PM   #2081
Bensen is offline Bensen  Belgium
Bensen's Avatar
Default Crescendo 1982 - 2pairs of output devices
In my first builds of this amp I had some oscillation issues. Since my last rebuild (+-2001) everything runs fine.
Old 24th November 2011, 08:43 PM   #2082
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Default 20 years old chip wine
A 20 years old chip preamp this one. Came for changing log pot from the friend I had given it a long time ago. It is an OPA627 unity gain buffer feeding an OPA637 X6 gain stage sandwiching the volume control. Fully DC coupled with offset trimmers for each stage. Had made a large hand drawn PCB for it back then including routing for many inputs and rec out select all the way back to a row of RCA's meeting the board. Had simply cut out some aluminum panels and put it together with stainless steel screws and Fender Tele knobs. Automotive paint job non the less. I remember to had selected the 627-637 just from a BB brochure on intuition. Too expensive to stock, the official representative company had told me in yr 1991. Two months on the wait on special order and many dollars for the era... Very good passive components like Holco and Vishay, separate PSU, Teflon silver wiring, and what do you know, still measures and sounds clean as a whistle, and smooth. Especially with the new pot, very good imaging. Can pass a very nice 200kHz square wave, won't clip before 29V Pk-Pk sine wave, FFT attached (0dBFS=2VRMS). Nice to preserve an oldie.
Old 25th November 2011, 12:58 AM   #2083
rfj5106 is offline rfj5106  United States
Hello Salas,
How did you do that beautiful paint job?
Richard Jenkins
Old 25th November 2011, 01:42 AM   #2084
Salas's Avatar
I gave the aluminum panels to a mate that was working in a paint shop at the time. And he used some leftover paint from when he had done his Vespa scooter. Really. Then it got renewed 15yrs later by the guy I gave it to. In an automotive paint shop. Check out how it reflects. Good in squares too. That one was a 20KHz square.
Old 25th November 2011, 08:02 PM   #2085
FastEddy's Avatar
Salas: Other than those two buggers / harmonics @ 2k, ~3.3k ... ~120++ db down, all the way across, is still very impressive. All that plus a clean 20k square wave passthrough ...
Maybe a "re-visit" to this design is in order ... using plastic caps around the newer op-amps and other tweaks? (I might like to have one, me-self. )
Old 25th November 2011, 11:27 PM   #2086
This one would have been a plain Blameless, but ended up a derivative of the DIYAmp (PCB layout is my own, transformer is only a 30-0-30 V unit).
http://www.diyaudio.com/forums/solid...-diyaudio.html
The performance is as promised. Big thanks to OS!
Case top and bottom are 2mm anodized aluminum sheets.
Front and back are sanded 100x6mm aluminum flat bar.
Heat sinks are Modushop/Hifi 2000 300x80mm, drilled and tapped 8-32 to hold the six sides together.
The power devices leads will be trimmed flush. They were left in case the mounting arrangement had to be changed.
The FFT was done with an emu0204 unit and has to be taken for what it is worth.
The 60/180/300/420/540 Hz noise visible seems to be coming directly from the transformer. It can be canceled almost totally by rotating the toroid around its bolt, at the expense of the other channel. Both channels are audibly silent.
File Type: png ss01 fft blame L, 10V, 10ohm, ifbox-20dB.png (120.2 KB, 418 views)
File Type: jpg ssfft emu0204 loopback, -12dB in_cr.jpg (98.6 KB, 227 views)
Old 26th November 2011, 09:29 AM   #2087
Nrik is offline Nrik  Denmark
Beautiful :-)
STOP - Hammertime!
Old 26th November 2011, 11:47 AM   #2088
kees52 is offline kees52  Netherlands
also a beauty, very low thd, but how it sounds with so low thd because the first and second harmonic is importand for the amp character, maybe this one sounds very lean?
what do you use for measurement? of thd, I look for good software and mike.
it is beautifull made.
regards
Old 26th November 2011, 01:41 PM   #2089
Salas's Avatar
I believe that the 10uF Stargets decouple it fine, there is no ringing in square waves, and there is no glassiness subjectively. A parallel regulator would make it more juicy. I must be having the hand drawn layout ''modules'' around the chips somewhere, but I could not readily find them to post them for you.
Old 26th November 2011, 01:49 PM   #2090
regards
To me it sounds great - but I have tin ears
I do believe the speakers to be the bottleneck in the chain though.
The measurement is done using an E-MU0204 USB DAC/ADC unit at 24bit/192kHz:
E-MU 0204 USB
The input is routed via a homemade 0/-10/-20/-30/-40 dB attenuation box with zener clamps to protect the ADC.
The ADC can only take 2 Vrms maximum, so I use 20 dB attenuation in that graph. The software is SpectraPlus. The numbers shown on the graph do not mean much - the E-MU runs out of steam above 30 kHz.
10 V, 20 kHz square wave into 10ohm/47nF attached.
Copyright ©1999-2013 diyAudio
