#211 |
the fact I designed fet devices to pick up radio frequencies at 15 years old could mean that basic knowledge is acquired, no to mention my industrial engineering degree (but that is another kind of relation to FET as we use it to control power devices
#212 |
thanks a lot for the schematic! in fact i had in mind to replace the fets by a bc5xx in darlington.
#213 |
the bf245 is a FET
the idea was a monstre with no FET at all ...
#214 | ||
#215 |
Banned
ericfe1975,
what`s your problem with JFETs? You should stick to the original design, taking your confusing ideas into consideration, it`s most unlikely that you can improve it. |
#216 |
Hello,
Actually, if you want to make a Le monstre without fets, it's basically becoming a Hiraga 20w, all bipolar : http://www.tcaas.btinternet.co.uk/hiraga2.htm and here on diyaudio: Hiraga 20W class A But the sound is believed to be different, more precise but less transparent from Hiraga himself opinion. But once again, nothing wrong with fets and you get a nice quadratic curve from them, not a nasty exponential! Regards |
#217 |
lumba please explain which idea confuses you , i am sure we can help you.
Yes i have noticed that a monster without jfet is like a "la classe classe A hiraga " .Well as Mr pass said, after all those years of progress for sure the monster can take some benefits. the point is not "improving" the monster, here the point is trying a le monstre without jfet and hear it. I do not belive that someone serious may have the arrogance to say " you know what? i am going to improve one of the best design in a class audio simply removing the fets" and certainly this is not my case. I am not saying either that jfet sound bad. not at all!!! every jfeted amp i've heard sound very clear and warm. thx for the schematic, i just got a good one in my own work, fully implemented thanks to the clarty of my ideas ( lumba )see you later. |
#218 | |
Having built and listened to both amplifiers i would agree with this comment. both amplfiers are excellent. -Dan |
#219 |
Dear all,
I am thinking of powering this 8W amplifier using batteries only, and recharge them after use. I need to ask a few things in order to avoid spending extra money on this. 1. What is the current consumption of the amplifier? (each channel) 2. Can I connect two identical batteries in series in order to take +12V, GND, -12V ? (just to make sure) 3. I have two 80AH 12V deep cycle lead acid batteries. About how much the operation time will be? 4. Can I use just two batteries for both channels? (the same psu for both channels) 5. Finally, can I leave the batteries stand alone to power the amplifier or do I need to connect capacitors parallel to them? And what could be the effect in sound when using no capacitors at all? (not so fast responce, etc) I yould appreciate a helpful answer in these five points which will save me extra cost. Best regards
Great DIY site: http://www.neazoi.com |
#220 |
some of your questions answered
http://forum.zelfbouwaudio.nl/download.php?id=16633 and ad 1) and 3) (if I'm not mistaken) 1A and therefore 80 hours. I suspect the last hours won't be as good
| Conversion of Hiraga's "Le Monstre" to a Circlotron | tiefbassuebertr | Solid State | 12 | 1st May 2011 08:26 AM |
| Hiraga Monstre with SMPS? | weissi | Solid State | 2 | 25th July 2008 10:44 PM |
| Hiraga 30W vs. Le Monstre | JohanH | Solid State | 103 | 14th April 2008 11:27 PM |
| HIRAGA Monstre amplifier modules | a333bt | Swap Meet | 5 | 14th October 2007 04:11 PM |
| Page generated in 0.12459 seconds (77.49% PHP - 22.51% MySQL) with 11 queries |
