Old 28th June 2002, 11:46 AM   #1
Default Is this a good way to simulate the sound of tubes??
I've just designed this schematic, and I'm wondering if this is a good method to simulate the warm sound of tube amps. I've designed it for someone who has an electric guitar but no tube amp, so I ask you guys if this is a good method to make a "tubebox" before I'll deliver it to him.
with R3 you can adjust the "tube-distortion" and with R5 you can adjust the gain.
Thanks,
HB.
Old 28th June 2002, 12:15 PM   #2
yeti is offline yeti  Germany
I'd work with one diode only, because this qill give you mainly even order harmonics,which are more like tube sound.
Your setup is similar to a so called "Fuzz Box",which gives odd harmonics,very harsh and ringing sound.
regards,
Arne
Old 28th June 2002, 02:31 PM   #3
paulb is offline paulb  Canada
Some feel that the "warm sound of tubes" is just added distortion. Others (and probably most here) disagree.
But this is for a guitar, so fidelity is not the prime consideration. Try it.
Old 28th June 2002, 03:20 PM   #4
I don't think you'll be satisfied with the sound of this schematic..
The output of a typical guitar will be around 200mV transient for humbuckers and about 100mV for single coils, so the diodes won't reach conductive state...
I can recommend the www.harmonycentral.com site! look for effects and then look for schematics... and a world of schematic information will be at your disposal..
personally I believe that the compression and bias shifting in tube amp is a key-factor of their signature sound.. the best way to accomplish that is by using single ended capacitive coupled stage without feedback ... try a cascade of N-JFET's, biased sub-optimal... reduce low-frequency transfer (to reduce intermodulation) to about -40dB at 1Khz and cut highs after the stage from about 1KHz ... for a nice sustained sound you'll need something like 40dB gain beyond headroom...
goodluck!
gr,
Thijs
Old 28th June 2002, 04:00 PM   #5
MRehorst's Avatar
Try simulating this circuit in SwCADIII and dump the output to a .wav file. Then you can listen to it and know what it will sound like.
If you want to go all-out, get any .wav file (rip it off a CD) of a guitar and use it as input to your circuit. Then you can see exactly what the circuit will do to the sound of a guitar.
MR
Old 28th June 2002, 08:23 PM   #6
The one and only
Nelson Pass's Avatar
I've built a number of circuits that think along those lines,
and none of them sounded like tubes to me. I think people
trying to make tubes out of transistors are barking up the
wrong tree
Old 28th June 2002, 08:38 PM   #7
tiroth is offline tiroth  United States
Yup. Why not lash together a simple line-level cathode follower or plate amp with a signal tube and go from there. Low plate voltage or low bias will definitely get you tube-induced distortion.
Old 29th June 2002, 11:07 AM   #8
Hey thanks guys,
Nelson, I was wrong: the schematic is not to make it sound like tubes, but to simulate a tube amp running into saturation (you'd better not try this with transistor amps huh, unless you are a squary heavy metal freak or something )
tschrama, yes I know that the schematic won't work with that low voltages, I've forgotten two resistors in the input stage, it must be an amp with gain x20 instead of a buffer.
thanks for SwCADIII tip, I'll first give it a try with that.
Best regards,
HB...
Old 29th June 2002, 11:52 AM   #9
Lisandro_P's Avatar
Send a message via ICQ to Lisandro_P
I'd use the Tech21 (www.tech21nyc.com) approach; get an old tube amp schematic and replace the tube gain stages with jfet ones. Suposedly it works great.
Old 29th June 2002, 01:04 PM   #10
hmmm, tubes and fets, unfortunately I've never experienced with them before so I think that it will be something for the future.
That's the negative point about my education: I'm studying electronics but we've never seen anything about tubes and almost nothing about fets etc... But we've done a lot of researche and experiments with transistors and opamps, so schematics with transistors won't be a huge problem to me.
I'm going to get myself a good book of the local library here and start reading articles about fets and tubes, and then I'll try some liitle experiments to get started with them.
I remember something about fets: is it true that you may never touch the gate, otherwise it will be damaged because of it's very high input impedance or something like that. Is it true that a little wire is connected between the pins of fets to protect them in case that they aren't placed on a pcb?
Can anybody confirm this because I'm not sure about it...
HB.
What makes the good guitar pickup sound so good? darkfenriz Instruments and Amps 15 1st March 2009 11:46 PM
The sound of... tubes ! Cobra2 Tubes / Valves 65 1st February 2007 08:40 AM
tubes sound A'af Tubes / Valves 127 28th April 2006 12:38 PM
Page generated in 0.10282 seconds (85.86% PHP - 14.14% MySQL) with 11 queries
