i don't think elektor knows guitar well. elektor tube box isn't what i'm looking for. later i build sansamp classic clone
C1.PDF - 4shared.com - document sharing - download
here's epress pcb file c1 main.pcb - 4shared.com - online file sharing and storage - download
it's awesome, but for heavy metal GT2 will do better
A solid state amp that comes close to a good tube amp like 300B is in my experience the current dump circuit from Quad. They are strong in the mid/low section and produces 'music'. To add some 'distortion' i added a carbon composite resistor in serie of the signal.
Lookup AC30SIM by Stephen Moeller. It's not available online anymore but you might try to contact mr. Moeller by e-mail.
It is a complete simulator of VOX AC30 consisting of preamp stage, power amp stage (both with different freq. response and different distorition characteristics) and passive LC speaker simulator.
It really rocks and sounds like a real tube-amp.
Simple circuits like those seen above will never sound like a tube amp - unless one replace the solid state devices with tubes.
I use a soft limiter to emulate tube in overdrive.
Use an op-amp stage with two transistors in the feedback loop controlled by a pot.
