Old 29th May 2004, 10:58 AM   #1
Tyimo is offline Tyimo  Hungary
Default Ion Obelisk
Hi!
Here is The Ion Obelisk! It is a Class AB 30W amp with astonishing musical sound. The designer was Richard M. Hay ( also designer of some Radfords! ) The Ion is the basic of the legendary Nytech amps.
It is easy and cheap to build and living with it too. (small and little heat).
The amp build with turn on thump blocker and overcurrent protection.
I didn’t say that it is the best amp, but it can easily outperform many comercial amps.
I will continue with part list, more detail and some more photo.
The schematic is a version of the Ion Obelisk.
Greetings for every Diyer!
Old 29th May 2004, 12:42 PM   #2
jam is offline jam  United States
jam's Avatar
Tyimo,
Thanks.
Old 29th May 2004, 10:59 PM   #3
djk is offline djk
djk's Avatar
Looks almost the same as a NAD 3020.
Old 29th May 2004, 11:08 PM   #4
Nothing like a NAD 3020, remotely.
The Ion was an update of the Nytech, and has similarities
with other UK single rail designs, all of them not good IMO.
The basic Mission Cyrus circuit is far superior IMO.
sreten.
Old 29th May 2004, 11:23 PM   #5
destroyer X's Avatar
Default Destroyer X will turn into Constructor one
Good!. thanks Hungary!
Send part list please. I am waiting walking from left to rigth in my apartment... i will make a trail so much i am passing same place to see your parts! (not a joke, ansious, crazy to see it).
I will simulate it as it appear in forum.
Carlos
My Youtube channel; http://www.youtube.com/user/destroyersoueu?feature=mhee
Old 29th May 2004, 11:33 PM   #6
judge yourselves :
http://www.tcaas.btinternet.co.uk/index-4.htm
sreten.
Old 29th May 2004, 11:35 PM   #7
Default Tyimo, i want to know some of Pirro
Pirro Victory, a think Thermophiles, Greece...only General Pirro stay alive, whole warrior dead figthing.
We use as a say here, when you win something with too much efforts and with too much sadness.
If you like to inform, please, write some letter directly to my E Mail, this way, we will no scape from the thread amplifier.
nanabrother@yahoo.com
Thanks in advance by your kindness.
Carlos
Old 30th May 2004, 05:26 AM   #8
djk is offline djk
djk's Avatar
"Nothing like a NAD 3020, remotely."
Q601 and Q605 of the NAD comprise the voltage gain stages, other than being opposite polarity they are hooked up the same.
The Ion uses an active current source for the VAS, the NAD a bootstrap. Big deal.
Actually , AKSA claims it is a big deal, and that the bootstrap sounds better.
They both use complementary darlington connected output driver pairs. NAD uses discrete transistors.
The Ion has an output cap.
The Ion has foldback current limiting that will make nasty 'farting' sounds if activated driving low impedance loads.
Old 30th May 2004, 09:58 AM   #9
Default Hello Sreten an whole people in this thread
This problem is very difficult to Judge because i lived some experience alike that.
I decided to return some decades to find an amplifier, the new ones with simetrical, double simetrical thopologies in differential input, with pnp and npn sounds horrible, awfull to me... only good treble, and strange bass.
This way i returned eigthies, then i found one easy to construct Sony, and as i worked for them and i see the way they judge, passing whole day sitting and comparing hearing music, not instruments, with glass cleaner to President sitted together... and when finish they see graphics and instruments.... they know very well the good distortions, the bad ones ,... who is good and who is bad.
The choice was Sony thopology.... this way i put thopology and start to calculate whole amplifier since the beginning.... each resistor, each condenser..... do it again, other transistors and other voltage.... do you know what happened?.... very similar Sony... and i made thopology coppy, not entire amplifier coppy... then i put it to simulate, and latter i put it to work.... good sound.... interesting bass...not so good voice or treble...but interesting non precise bass.... without short bass tone...not a boom!..... it make a boooooooooooommmmmmm!...longest one, i prefered...personal taste.
Then, so happy i was, i made some damn pc board design, an scratch with transparent board and parts on it... easy to make and understand and copy, and construct..... do you know what happens.... exactly, or very close to P3A from Rodd Elliot... and Rodd make their amplifier before Japanese... i contact Sony friends and asked them when they made design.... Rodd was the first related Sony.
And someone asked P3A board.... i tried to send by mail... could not.. and i made the foolish, i put it on forum and some Sweeden man, do not remember the one, told me that this is no good, because Rodd was making PCboards.
I was ashamed because so fool i was... and i asked moderator to erase all thread, and they donne it for me.
In the real world, i do not copy Rodd, i copy Sony Thopology only.... and matched with Rodd P3A as an accident.
This way, this schematic shown, may have absolutely nothing related to NAD schematic.... only damn similarities, that can happens because i lived this sittuation in true life moment!
By the way, can you inform me, in forum or directly to mail adress, How is this NAD sound, have you heard it?.... how this undistorting method works, and what problem this no distortion method can create when not working yet. If you can help me....heellllp!
Thanks by attention
Carlos
Old 30th May 2004, 12:01 PM   #10
how does a NAD3020 sound ? Interesting question.
I've heard several over the past 25 years or so in different types
of systems from serious "HiFi" to thrown together stuff.
Well first off it goes louder than you would think and it is does
not have any problems with difficult loads. Compared to other
rated amplifiers at the time (I had a supposedly "good" JVC)
it sounded relatively unrestricted and dynamic.
However over the years your discrimination improves, and
the 3020 is not the last word in amplifier design. The internal
wiring is far too messy for it to achieve high resolution.
But a landmark design - and still very listenable to.
There were several single ended input single rail designs in the
The NAD's day like the Nytech / Ion. I can't remember the models
off-hand, they all sounded nice but lacked real power and some
struggled with less than ideal loads.
IMO the Mission Cyrus 1 set the benchmark for serious "HiFi"
budget amplifiers. Good resolution, good imaging, can be
played loud without falling apart, sounds "together".
For the stock amplifier bass is slightly weak.
The Cyrus II and PSX comprehensively sort that out.
sreten.
obelisk shape karellen Planars & Exotics 3 2nd September 2009 12:54 AM
nytech obelisk ca102 reddish75 Solid State 0 1st September 2008 11:44 PM
Ion Obelisk 3 Spev Solid State 9 24th November 2006 03:28 PM
Shahinian OBELISK DIY in details HighTech Multi-Way 0 29th September 2006 07:59 PM
Page generated in 0.13328 seconds (82.98% PHP - 17.02% MySQL) with 11 queries
