Very simple quasi complimentary MOSFET amplifier
This is how my output coil looks like.
15 turns wound on a former from half an old CRT monitor transformer. 😎
(before any complaint about R25, there is another one under the board...)
G'day all,
Please see attached where would this be coming from, just finished running some tests.
Used 2sa970,2cs2240,mje350, bd139, irfp240 & mjl4281 at 42v rails, bias set around 100ma but not stable when increasing signal.
Any help appreciated.
Cheers
Bruce
Now that takes me back! Final year uni project had the same symptoms. Stable at low signal levels, oscillated at high signal levels.
At the time we (my supervisor and I) believed the cause was non linearity of gain and/or capacitance which was changing the loop gain.
In my case I had mosfets "back to front" to try and mitigate the 12V Vgs "tax". The problem was that the devices I had then were extremely non-linear around device turn on. Particularly the gate to source capacitance.
I'd be looking to see if you're pushing some device into an area of operation where its gain (or Cgs/gd) are changing rapidly.
Having built 3 variants of the Quasi - and they all work with great stability, all I can suggest is to switch to the recommended small signal devices. Use 2N5401 and 2N5501 and KSA1381's as a baseline case (they are plentiful and cheap). IRFP240 works I know. MJL21194 seems like it should work. Are your DC voltages at all the nodes consistent with predicted or measured points by others who have working examples?
Ok have changed the inputs as per drawing, had to wind up the bias to settle it down. It would seem the mjl4281 looking through other threads is a problematic device with oscillations.
Right time to let it burn in.
Bruce
