Peter,
It am sure you know what you meant, but I saw a risk your
phrasing could be misinterpreted as saying that it really isn't
dangerous, but just a forum rule. I wanted to clarify so nobody
gets the wrong impression here. It wasn't meant to pick on you,
and I forgot to point that out. Sorry. I just wanted to try
explaining why it is dangerous.
I am well aware of the danger of that, and I would never recommended to use such setups (when device is powered directly from mains). I also realized my incorrect wording and that's why I explained/corrected it.
A moderator should always be an example of correct safety practices, I know that too
Matttcattt said:sorry to cause all the fuss. i understand the dangers of mains. i did not know that this was a forum rule, i will re-read the rules now.
would it work with +/-115vDC using an isolation transformer (1:1 windings) from the mains?
5000W with +/-115v is about 20A isnt it?
did you know, that first off that transformer would still be huge... second when rectifying AC to DC you times the voltage by 1.41 giving you +-163 volts, and thirdly, you need a centre tap...
Eh, well not, if you add the centre tap you suggest you rather
get +/- 82 V (or whatever is is, too lazy to calculate it now).
VT Calais said:Does anyone have any experience with
THIS or any other 1KW amp?
Where is the scheme ?
Re: Re: Has any one built this 1KW amp?
Anthony Holton only made the AV800 available in PCB form as far as I know. I have built up a few of the AV800's and they are nearing completion.
in practice (i was about to say "in theory"), what is the highest voltage rails you could have (DC)?
230vAC x 1.41 = 324.3vDC
using 2 seperate mains feeds, you could get +/-324vDC. this would be okay with 400v output devices, but could you get other components to work at this voltage?
Matttcattt said:using 2 seperate mains feeds, you could get +/-324vDC. this would be okay with 400v output devices,
with +/- 324v DC, you are talking about potential voltage drops on the output devices of 324vx2=650v before any safety factors.
Realistically, you are probably talking about 1000v Vce/Vds devices. they are probably difficult to find and you may have to parallel a lot of them to drive 8ohm speakers,
I think there's a way you can cascade a set of transistors vertically, so that they can stand more voltage all together.
I rarely see this used in audio, but I know that it's been done.
At least it's a relatively useful way to make 250V transistors work in a 650V amplifier.
1000W RMS Power Amp
As someone who builds 1000W amps every day, I have had spectacular resilts with the ICEPower modules from B&). The 1000A costa us less than US$100.00 a unit.
As well, the 1000ASP is available to us for under US$200.00 and it includes a regulated switching 120/240V Power supply. Plus, the 1000ASP power supply has enough power capacity, it can drive a 1000A module, giving you 2000W of sub woofer power.
Alternately, it can drive 2 of the 500A modules to give you plenty of mid and high on a tri-amp system.
The prices are 100+ OEM prices. You will have to lookaround to see who may sell them. See:
http://www.powerhouse.bang-olufsen.com/sw1022.asp
Matttcattt said:in practice (i was about to say "in theory"), what is the highest voltage rails you could have (DC)?
maybe i will re-write my question. what would be the highest rail voltage (DC) that you would use?
Re: Burn up?
Sir , The thermal Tracking is very well performed by diode connected transistors which are mounted on heatsink.
If u insist , I can also put a Vbe multiplier using transistor.
Ampman
richie00boy said:Hi amp_man_1
I like your schematic, but I notice that the bias voltage is set only using a pot, hence there can be no thermal tracking. Isn't this unwise with such a high power design and BJTs?
Ampman
Thank you amp_man. I would have thought that a Vbe muliplier would be a better way to do it than the 2 diode-connected transistors + pot?
Also, why is Q3 and Q4 on the o/p stage made from paralleled devices? A single device would easily handle current required, I would think.
Commentable Thoughts
Hey man
The parallel drivers play their role when someone is driving 2 Ohms load at low frequency , therefore for ample current drive requirements the paralleling is required.
Ampman
richie00boy said:Thank you amp_man. I would have thought that a Vbe muliplier would be a better way to do it than the 2 diode-connected transistors + pot?
Hey man
Ampman
- Has any one built this 1KW amp?
