No NFB line amp (GainWire mk2) - Page 3 - diyAudio
Old 11th May 2013, 10:44 AM   #21
matze is offline matze  Germany
Originally Posted by dadod View Post
Hi Matthias,
Here is the gain plot without output buffer. First one is without C2 and second with C2.
BR damir
Hi Damir,
thanks. Cascoding often seems to require some extra tricks. Here in the current mirror, there in the buffer.
Kind regards,
Matthias
Old 11th May 2013, 10:49 AM   #22
Hi Matthias,
BR damir
I have to wonder whether that peaking is not coming from the current mirrors. All current mirrors have some peaking around the 2-15 Mhz. The EF assisted mirror has much higher peaking than the standard one.
You could try placing small value cap from base to emitter of Q21 and Q22.
Old 11th May 2013, 12:04 PM   #23
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by manso View Post
Interesting, some performance is lost. Can it be made stable if you remove the zobel and only the RC in place ??
I think it's possible, but I am more interested in simpler output buffer and I will show you what I've found later.
Damir
Old 11th May 2013, 12:11 PM   #24
dadod's Avatar
It helps, the peaking no more, but I don't like the brick wall like plot, and if I keep C2 connected it looks much smoother.
Damir
File Type: jpg GainWire-mk2-e-elvee-dado-gainpeaking-noC2.jpg (242.4 KB, 904 views)
File Type: jpg GainWire-mk2-e-elvee-dado-gainpeaking-C2.jpg (236.7 KB, 857 views)
Old 11th May 2013, 12:18 PM   #25
Damir
Any of those measures will suffice indeed.
I asked mainly because some have no knowledge about the peaking in current mirrors and this is a very good example of where these anomalies many times originate.
Simpler than diamond buffer ?? I think thats as simple as can be had for such performance.
Old 11th May 2013, 12:49 PM   #26
dadod's Avatar
Could you take a look at first post in this thread and tell me what you think about that output buffer?
Damir
Old 11th May 2013, 02:36 PM   #27
dadod's Avatar
This is schematic I like the most, with simple output buffer.
THD1k at 2 V output is just 0.000066%
Output impedance is 23 ohm flat from DC up to 100 kHz
I kept output resistor, now lower at 22 ohm, to be less sensitive to the long cable capacitance
PSRR abouth 90 dB
Damir
Old 12th May 2013, 09:40 PM   #28
dadod's Avatar
No comments on this simple output buffer?
Old 13th May 2013, 07:28 AM   #29
dadod's Avatar
100 kHz square wave simulation.
Old 14th May 2013, 12:31 PM   #30
dadod's Avatar
This shunt regulator(stabilizer) could be used as the power supply for this lineamp.
Line stage with u-follower and nfb Groucho2004 Tubes / Valves 6 26th April 2012 11:00 PM
Cambridge A1 (mk2) Line-Amp Stage Power Suppy vcmarshall Solid State 0 25th April 2010 07:16 PM
Another no overall NFB amp npnp Solid State 9 8th April 2010 10:12 PM
Improved PSU for Technics SL1210 MK2 and SP 10 MK2 (and others) beetle Analogue Source 21 20th January 2010 12:25 AM
GainWire Mad_K Chip Amps 7 29th December 2003 06:48 AM
Copyright 1999-2017 diyAudio
