Hello!
I want to build a tiny transistor amplifier, using very few, cheap and commonly available parts (no opamps or ICs). Basically something with regular TO-92 style transistors, or similar. Powered by a simple 9-12 volt wall wart. Just a power switch and a passive volume control. Sound quality is not important, but a bonus. Basically I want to build something like the amp found in cheap computer speakers. I've been looking around and cannot really find what I need... Does anyone know where I can find a pre-made schematic for something like this? Thanks! |
#2 |
Look at late 1960s/early 70s radio/electronics magazines. They were full of this sort of thing.
#3 |
#4 |
Sometimes a square peg fits a round hole just fine
#5 |
Do a search on the net for Sinclair Z30. Remember to add emitter resistors.
#7 |
Are you still there?
Here's a simple output stage I used for a tranny radio. Works well. John |
#8 | |
Your misguided. You can't build an amplifier just using small signal transistors. Its stops being simple very quickly when you realise just how rubbish your simple amplifier is compared to simple IC circuits that have been around for years, and for good reason, they are simple, and they work well. No computer speakers use an amplifier of your description. The latest use mini class d driven from the 5V supply of USB ports. Older ones almost exclusively use chip-amps. With a 12V supply your talking car audio and there is simply loads of options, around 5W / 4 ohms for a simple circuit and up to 20W for bridged into 4 ohms. IMO just buy a cheap kit off e-pray. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 6th February 2012 at 11:24 PM. |
#9 |
- this is DIY, no kits! There's a truck load of web sites with simple amps. And power devices may not be so critical if listening to small speakers at low volume - when I listen to my computer speakers I'm guessing they're playing at 1/8 W. But it is a stretch when a couple of power transistors can be had cheaply these days - even a pair of old 2N3055's from an old power supply or something.
http://www.electro-tech-online.com/d...datasheet.html http://musicouch.com/instruments/str...mple-receiver/
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. Last edited by Bigun; 7th February 2012 at 12:14 AM. |
#10 |
Here is an original proposition.
Despite its simplicity, it even manages to include an auto-bias circuit:
| Beautiful super mini 6F3 2.5Wx2 tube amplifier - group buy | siliconray | Siliconray Online Electronics Store | 5 | 17th October 2011 02:55 PM |
| Super Triode Connection Amplifier Build with 6BM8 and 6AK5 | DerFly | Tubes / Valves | 35 | 3rd November 2009 07:45 AM |
| i want to build a amp with 1-4 Transistor MAX!! -very simple | Dj BASS AMP | Solid State | 61 | 20th June 2005 01:10 PM |
| Page generated in 0.10333 seconds (76.91% PHP - 23.09% MySQL) with 11 queries |
