#431 |
I second that, Nico. Alex is the best pcb artist I've seen on DIYaudio, and he's fast, too.
I spend tens of hours on mine, and it's always difficult to get that artistic look, which necessary or not, I'm driven to achieve. I suspect it's like juggling, you can either do it or you can't. Cheers, Hugh PS: Here are six NAKSA 100 modules, to give some idea of how mine look. |
#432 |
I just started playing with Pcb software and quickly realized the time and effort it would take to master, much less do quickly. Alex is gifted.
#433 | |
#434 | |
- BC550C, BC560C have different pin layout (base connection pin in the middle) - left feedback 100 ohm resistor is unconnected, connect it to the GND - change two 470uF/16V elco to 1000uF/16V - on the left side of the input connector place a 10 ohm GND lift resistor (opposite side to 10k resistor) - 1k/2W resistor should be connected to the rails at FUSE output - in series with each 1k/2W resistor please connect green LED to indicate power - please put MUR160 (smaller) instead of MUR460 - Vbe multiplier transistor should be BD139 instead of BC550C, screw mounting to heatsink - please align output transistors symmetricaly from the left/right PCB edge - please give +1mm more space between outputs/drivers (too close to each other) - trimer 1k should be near to BD139, you have than only two jumpers wires - please put (sch below) 10 ohm emitter resistor to Vbe multiplier - rearrange positions of 1k/2W resistor, 1uF, 10nF, to put 10000uF/63V on PCB - place one more GND connection (SPK-) in between two existing (three in the line) - place only one OUT pin connector in the middle - 1k feedback resistors should be connected at exact OUT pin (not 2 cm away) - 1k from each gate of IRF to emitter of the output BJT are missing - please put two 15V/0,5W zener diodes in series (chatodes towards each other) from gate to source of each IRF (overvoltage gate protection) - heatsink from each power diode MUR860, should have holder solder pin, like at BF's - the name of the PCB: SSA BIGBT Basic - the schematic is by Lazy Cat
#435 | |
Why two decoupling caps for the input voltage shunt reg? Why not just put the 1m cap in place of the 16u cap to the LED? Sheldon |
#436 |
Hi Sheldon,
10uF/16V elcos are decoupling current source/sink generators (sense BJT) not +/-15V rails
#437 | |
Sheldon Last edited by Sheldon; 25th August 2011 at 03:16 PM. |
#438 |
I know but this amp has several MHz power bandwidth and replacing current supply resistor with current source/sink is critical. All unwanted AC, RF, ripple, ... must be rejected from sense BJT's collector to prevent any kind of oscillations in CSS generators.
#439 |
Thanks.
#440 | |
If supply voltages are higher I recommend BF471/BF472, 2SA1478/2SC3788 or similar TO-126 case high bandwidth transistors.
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
| Page generated in 0.38652 seconds (100.00% PHP - 0% MySQL) with 10 queries |
