#851 | |||
Good electrolytics like in the schematic are preferable, they provide decoupling and damping Quote:
#852 |
I have just tested the 2SA1930/2SC5171 pair as drivers and VAS.
The samples kindly provided by Daniel are authentic, and they perform remarkably well in the Circlophone. The all-plastic construction makes mounting on a heatsink very easy, and the case has a low enough thermal resistance of its own for the VAS to be left without heatsink. In summary, an excellent choice: high availability, good performances and ease of use: a dream.
#853 |
this is an interesting unusual desing,
I have bookmarked this thread, I hope i found the time for an deeper analisys. P. |
#854 | |
The information is presented tight and compact. It also has example schematics, a verified parts shopping feature, many pcb layouts, a perfboard method, a build/art gallery, and accessories. Circlophone has a live sound characteristic. There are many available parts and perhaps you already have most of them. |
#855 | |
MJ802G 30a, MJW1820G 30a, MJE13009G FJA13009TU While I was working on it, some of the program code on the builder's thread found those devices automatically. So, temporarily, I have constricted the search to omit them, because I do not know if they are suitable. |
#856 |
I didn't find data on the MJW1820.
Here is the figure of merit for the others: MJ802 0.71 MJE/FJA13009 1.2 But the absolute value of the Hfe for the 13009 is very low, and this will put severe stress on the drivers.
#857 | |
MJW1820? Sorry for the typo. It is MJW18020G, a 250w plastic. The links below open datasheets. Here are the stragglers: MJW18020G 30a, 250w HFE14 MJE18008G 8a, 125w, HFE14 FJP13007H1TU 8a, 80w, HFE15 |
#858 |
MJW18020G 30a, 250w HFE14: 2.36
The 2.36 figure is excellent, but unfortunately since it is a high voltage transistor, the useful Hfe is low, around ~30, and this will demand hefty drivers. These two have a really too low gain (<10) to be of any use: MJE18008G 8a, 125w, HFE14 FJP13007H1TU 8a, 80w, HFE15
#859 |
An extremely rugged multi emitter transistor, also excellent for the Circlophone: the Sanken 2SC2922
#860 | |
With this transistor, a good layout, good bypassing and optimum compensation is compulsory: with the 50MHz Ft, any imperfection will result in oscillations.
| Need help with OB design - cheap, cheap, cheap | djn | Multi-Way | 38 | 30th May 2010 06:26 AM |
| Scosche SPL meter: Cheap find with potential, or cheap junk? | theAnonymous1 | Everything Else | 5 | 11th October 2006 03:40 AM |
| Alpine cda-9831 vs. 9833 vs. 9835 | cbecker33 | Car Audio | 3 | 10th December 2004 12:47 PM |
