#161 |
I've been living with this amp for about six months at the heart of my active crossover Linkwitz Pluto-clone (a.k.a. Pluto-Nix) speakers.
The amp never fails to impress. Sonics are dynamic and crystal clear w/ 100W of beautiful Thermaltrak power. The speaker protection/voltage regulator is a work of genius; a John Linsley Hood (JLH) design. The amp was a joy to build. Hopefully this amp will serve many years of enjoyment. If you're interested in a DIY Class AB you can't go wrong with this design. Single side board layouts, schematics, and BOM are available to craft by hand. Excellent work, dado! |
#162 |
Greenm01,
Thank you for your comment. Here is improved PCB single side Layout if someone is interested I will provide pdf files. dado |
#163 | |
Most notably it looks like you changed the grounding scheme and removed the output inductor? It also looks like you added an option for a through-hole J3 next to the SMD /Mason |
#164 |
Dado,
Please provide PCB Pdf files. Joshvi |
#165 | |
There is no changes in the schematic just the layout. The output inductor and coresponding resistor are moved directly to the loudspeaker terminals, as suggested in the other thread. I will attached the pdf files tomorow. regards Damir |
#166 |
PCB pdf files.
dado |
#167 |
What about asking for copies of the relevant posts in the other Threads to be brought across to here?
Make a list and ask the Mods to implement the copying. |
#168 |
#169 |
May I have Single side board layouts, schematics, and BOM's to craft by hand photo, for PSU and speaker protection/voltage regulator,please?
Thanks,
#170 | |
dado |
| Compact Sized LME49810/11 +ThermalTrak Amp | panson_hk | Chip Amps | 301 | 1st January 2013 05:22 PM |
| MEMDIST POWER AMP + JC + TMC - help to set up | padamiecki | Solid State | 7 | 7th December 2011 12:34 PM |
| New 200 watt Kit amp features ultra low distortion and Thermaltrak devices | snoopy | Solid State | 56 | 3rd May 2010 08:42 AM |
| Mini-Sized 49811 ThermalTrak Amp | panson_hk | Chip Amps | 3 | 1st April 2010 08:06 AM |
| What to do with TMC tube radio gear? | diamondsouled | Tubes / Valves | 4 | 31st March 2009 01:30 PM |
