Hello
The is a thread about a high performance amplifier called the Phoenix . >The values of the freq. comp. components are cc9 = 1nF & rc9 = 56R. BTW, they don't compensate Q16/16, rather Q22/23. Are these values for the output stage stability of Q22/Q23. >Regarding the temp. compensation, it's a bit tricky with this design. The point is that the loading on the VAS output should be kept as low as possible. Even a small capacitance of 10pF has already an effect on the performance. Now imagine what a classical Vbe multiplier will do, a TO126 tranny that is mounted on the heat sink...... Right! Also, we have issues with the thermal delay. When you are talking about the output loading of the VAS are you talking about the capacitance of the TO126 tranny would introduce when it is connected to the heatsink (GND). So it forms a capacitor from the VAS stage to ground - is this what you mean ?. The thermal track diodes of the NJL4281/4302 wouldnt they introduce a similar capacitive loading also. Regards Arthur |
#2 | |||
Something went wrong, as the component names have changed in the meantime. Looking at the latest schematic I mean Q15/16 (again). But actually, it compensates the whole OPS (only when clipping, of course). Quote:
The good news is that it is probably easier to reduce the compensation of an over compensated circuit than vice versa. I'm away this weekend, so till Monday. Cheers, E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) |
#3 |
Hello Edmond
I am away until this Thursday. Regards Arthur |
#4 |
Hello Edmond
Q1 an Q2 supply current , but what problem are you addressing with them. Regards Arthur |
#5 |
Hi Arthur,
Q1 & Q2 are normally off. When the output protection kicks in (which shortens the VAS output), these trannies limits the max. VAS current to about 20mA, otherwise this current will rise to a dangerous 40mA. Also a few other unwanted side effects are suppressed in this way. In the meantime I discovered an error in the op-amp model. The one we were using so far, is for dual op-amps. Consequently, the supply current is two times as high (10mA instead of 5mA). See also: Spice simulation So I had to modify not only the model but also the schematic. I also played with the ThermalTrak trannies. Results were very encouraging and I will soon drop the schematic of the new version (please, have a little patient with me). Cheers, E.
#6 |
edit > otherwise this current will rise to a dangerous 40mA.
should read as: otherwise this current will rise to a dangerous 70mA.
#7 |
Hi Arthur,
Here's the new version. Regrettably I don't have correct models of TT-trannies NJL4281/4302 (though I do have models of the TT-diodes). So for the moment, I'm still using the Sanken models. Please have careful look, in particular at D19 and D20. This clever configuration (courtesy of Bob Cordell) greatly reduces cross-conducting during fast transients. Don't hesitate to put your questions (probably many Cheers, E. PS: TDH20k is about 1ppm. Q16 & Q19, respectively Q17 & Q20 are thermally coupled.
#8 |
More on D19 & D20. This is what Bob Cordell said about it:
"The two “extra” ThermalTrak diodes, D3-4, are used between the emitters of the driver transistors to establish the idle current of the drivers while keeping the impedance between the emitters very small, so that the drivers can operate in push-pull to provide turn-on and turn-off current to the output transistors. Keeping the impedance between the driver emitters very low at high frequencies is essentially what is often done with the speedup capacitor. The ThermalTrak diodes make it possible to do this in a d.c. fashion with the necessary precision because they track the output transistor Vbe’s. " See also: Biasing/thermal compensation of Thermal Trak transistors I would highly recommend this scheme. And below a compilation of some comments, graphs and schematics about the ThermalTrak trannies and diodes. Cheers, E.
#9 |
Hello Edmond
Sorry I have not posted any questions yet, but I am just playing around with the most recent circuit (Pheonix7) to get some idea of all the things that you have done , it has lots of nice tricks. The output stage protection is is really nice the way it pulls the current away from the predrivers q16 and q17 in protection mode . Also the main clamp transistors q13 and q14 are also connected differently than in Pheonix6. Here is a question though why have you connected the collector of Q1 with the collector of Q13. More questions will follow. Regards Arthur |
#10 | |||
Indeed, many trick and many changes. Please take your time to digest them. Quote:
In the coming days, I will describe step by step the various function and (protective) FB loops, together with graphs of the phase and gain margin. Cheers, E.
| Anyone in Phoenix, AZ? | Lewis Moon | Swap Meet | 0 | 15th November 2009 07:06 PM |
| New Guy In Phoenix | Mindcrime | Introductions | 1 | 19th April 2007 05:16 PM |
| Was building Phoenix ... Now maybe Orion? | ¿GotJazz? | Multi-Way | 56 | 15th November 2004 01:14 AM |
| Phoenix questions | ¿GotJazz? | Multi-Way | 26 | 29th August 2004 04:16 PM |
| Linkwitz Phoenix | Oz_Audio | Multi-Way | 3 | 28th June 2002 07:27 AM |
| Page generated in 0.13731 seconds (81.30% PHP - 18.70% MySQL) with 11 queries |
