Amplifier based on Sony schematics.
50/100W 4/2R (20Hz-20kHz, 0,04% THD) 5Hz-50kHz +0,5/-3dB THD 0,005% (1kHz, 4R) |
#2 |
Mile , there some mistakes on the schematic..
#3 |
Input impedance: 220 ohm, hope it's driven from another power amplifier :-)
Or maybe you should consider using the non-inverting input ? Soren |
#4 |
#5 |
#6 |
There is part of original schematics. This is experimental amplifier. Any suggestion will be welcome.
Regards Mile |
#7 |
Quadral use higher value for feedback resistor to get higher input impedanse, or will be better to use noninverting input? Can this simple circuit have Sonys figures? It's remande me on Hafler preamp DH101.
#8 | |
If the MOSFET's are 150w and they only conduct on half cycles then that is 300watts per half cycle each MOSFET can stand.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#9 |
First thing interesting to me when I see Sony schematics is useing IRF540/IRF9540 in fully simetry design, and low THD. It's good circuit for playing and experiment.
#10 | |
But I donīt think this would be more than just measurable. On the other hand, lowering the values of the feedback resistors would improve speed and stability. Also, I would add identical resistors to the two input transistors where the collectors are tied to the supply rails now. Then, add an extra VAS transistor between the new resistors and the current VAS emitter. The "new" collectors should be grounded. This way, the VAS operates fully differential and distorsion is likely to drop significantly!
| IRF540/IRF9540 bias | bogdan_borko | Solid State | 34 | 17th May 2008 12:35 AM |
| can irf540 +irf9540 be tested with dmm | homertooties | Solid State | 2 | 13th November 2006 06:19 PM |
| irf540 and irf9540 can these be tested with a dmm | homertooties | Parts | 8 | 13th November 2006 10:36 AM |
| substitute for IRF9540/IRF540 | elementx | Chip Amps | 1 | 7th July 2006 05:09 PM |
| Irf540/irf9540 Amplifiers Schematic Collection | zox2003 | Solid State | 29 | 30th March 2005 10:22 PM |
| Page generated in 0.10752 seconds (76.28% PHP - 23.72% MySQL) with 11 queries |
