Use HX11
Thank you Mr. Mile for the suggestion
I found the PCB layouts designed by Mr. wiljj78 in post https://www.diyaudio.com/forums/sol...imate-fidelity-amplifier-229.html#post3516547. Hope this layout is not having errors. Thanks to wiljj78 for the layout design.
I could not find the schematic of HX11
Should I add more output pairs(1943/5200) for 200 Watts in 8 Ohms?
Sha
There is a version here: 100W Ultimate Fidelity Amplifier
I've not looked to see if it matches the PCB you have so check it out.
Ok, Thank you avtech23 for the support.
Sha
Sha
Hello Sha,
another good candidate for sub amp is apex bx 22.
regards
Prasi
regards
Prasi
BX22
APEX HX11 SCH
Sha
Hello Sha,
regards
Prasi
Thank you Prasi for the suggestion. Added to my list
Sha
Thank you for the scheme, I think I have most of the components except the IRFs
Between could you please clarify the below.
1. Output power into 8 Ohms(my preference is 200 watts into Ohms)
2. 60-0-60, Ampere rating
3. 30-0-30, Ampere rating
Thanks again for supporting and guiding us.
Sha
Sha
Hi, what is the best Apex amplifier for +70/-70VCC and full range frequencies?
A40, SR300...
A40, SR300...
Thank you for the suggestion. Where I find schema and pcb information. This thread is too big...
SR300 is from thread https://www.diyaudio.com/forums/solid-state/173462-studio-reference-amplifier-238.html#post4938798
Use Search
Use Search
Ok. I'll search...
Don't know if it is up to date.
A Directory of Apex Audio Amplifiers
TB1 volume preamp with loudness for use with TB2 and TB3.
Hi Mile. I dont have swich for loudness and i want to use jumper without loudness. How to connect jumpers? Thanks!
Hello sir
This 1 try
This 1 try
This 1 try
I try but have little gain. about 800mv at 1khz input. Do you now how to incre
ase gain? Thanks!
ase gain? Thanks!
Replace 1k8 with 470R for more gain...
- 100W Ultimate Fidelity Amplifier
