Old 25th August 2010, 04:38 PM   #311
RSK is offline RSK  Malaysia
Originally Posted by apexaudio View Post
There is IRF450 and it can be used also. MOSFETs are from IR not from SAMSUNG.
Yeah I was looking on the net for datasheet and samsung comes out??
But anyway I will try this NX14.
Raj.
Old 25th August 2010, 06:07 PM   #312
radio is offline radio  Macedonia
radio's Avatar
Default APEX AX-14 (modifications)!?
Hello Mickey!
I want to develop this amplifier Apex AX-14. I want to ask one question:
What changes should I do when I have the amplifier power of Us = + /-38V and the output thereof I want to turn the speakers with an impedance of 4 ohms??
Thank you in advance!
Old 25th August 2010, 06:44 PM   #313
apexaudio's Avatar
Originally Posted by radio View Post
Hello Mickey!
AX14 will work with +/-38V on 4ohms load without any changes.
http://apexaudio.rs/
Old 25th August 2010, 08:00 PM   #314
apexaudio's Avatar
Raj.
I use for test 20cm wire from pcb to the outputs on heatsink, NX14 work without problem. MOSFETs in TO3 case will work, just use short wire for stability.
Old 26th August 2010, 07:19 AM   #315
macd is offline macd  South Africa
Default RE... NX-14 Completed
Hi Apex,
Still no luck with my NX14. Looks like I have to assemble the second channel. Anyway I see there is a difference between the two boards(NX14 V1 and NX14V2). I see two 100R resistors on the layout but not on the schematic. See attachment. The 22uF 63V cap on the schematic is replaced with a 2.2uF cap on board.....is this okey......
Macd
Old 26th August 2010, 10:58 AM   #316
radio's Avatar
Hello ALL!!!
Audio Amplifier-comentar !!??
Tank youuu!
Old 2nd September 2010, 12:15 PM   #317
apexaudio's Avatar
Originally Posted by macd View Post
Hi Apex,
Macd
Two 100R resistor in series I use instead one 220R, 2,2uF is OK.
Do you measure voltages as I suggest?
Old 2nd September 2010, 04:22 PM   #318
apexaudio's Avatar
Hello ALL!!!
Tank youuu!
'Nikko' coment sound of AX14 in local forum:
[es] - seme/pcb zastita pojacala i zvucnika
Old 6th September 2010, 08:08 AM   #319
adrianm is offline adrianm  Philippines
Hi Mile, do you have a diy amp suitable for a 38-0-38 volts transformer? I prefer for a bipolar output stage.
Old 6th September 2010, 12:29 PM   #320
apexaudio's Avatar
AX14 will work with +/-56V DC rail voltage.
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
