#41 |
Here it is, hot off the scanner. Message me if you'd like the pdf instead (these jpgs were exported from the pdf since it was too big to attach here).
#42 |
hi dangus, this is great, genuine info. Now we know the inspiration source of F. de Dieuleveult.
#43 |
I built several of the audio amps ala Siliconix 1979 app note DA76-1. I still run the MOSfet amplifier today. Sounds as good as any tube amp even driving difficult complex loads such as Magnaplaners or full range electrostats. The 2N6658 are very linear and the Siliconix design used very little negative feedback. Closed loop BW was 800Khz. The extremely wide BW and very low negative feedback means this amp has the transparent sound quality of the best room heater tube amps. I used eight 2N6658 MOSFets instead of the twelve suggested by DA76-1. Here are a couple photo of my amplifier I built 30 years ago and still use.
http://i72.photobucket.com/albums/i1...etAudioAmp.jpg http://i72.photobucket.com/albums/i1...658MOSFets.jpg Last edited by Don Clement; 6th January 2011 at 07:45 PM. |
#44 |
Hi Don Clement,
very nice layout ! What modern semiconductors would you use today for implementing the "driver" current sources and current mirrors ? What modern NMOS would you use for the output devices ? Steph |
#45 | |
#46 | |
Anyway, expecting a single pair of NMOS devices to drive 2Ohm load at full swing of +/- 42V is simply asking too much. In my opinion the output stage in this topology should be very linear if driven in pure class A, better then complementary MOSFET A class. I wonder if somebody has tried it? Chip |
#47 |
Pretty good news, this is indeed waking up my interest for such topology. Thanks !
#48 | |
http://www.diyaudio.com/forums/solid...spice-urls.htm are close by the 2N6658 and its closely related Siliconix VN series ? The pics from "photopucket" I have save here, because there the pics was often deleted after short time Last edited by tiefbassuebertr; 17th October 2011 at 08:24 PM. |
#49 |
In theory, MOSFET transfer function is supposed to follow the square law. Thus A class push-pull stage of two identical (well matched) devices should exhibit distortion-free operation (at least in theory). It takes good phase splitter to ensure proper counter-phase operation.
One implementation is the PLH amplifier (however Mr. Pass preferred somewhat asymmetrical operation). Buzamp and other amps shown in this thread use diff pair as phase splitter which is supposedly better at the task (especially if cascoded). In reality MOSFET transfer curve deviates from the square law, so the distortion cancellation is not perfect. At higher frequencies non linear capacitance of the MOSFET contributes to further departure from ideal. Anyway I’m considering this topology for low power class A amplifier. Linearity of the output stage will hopefully allow good performance with just mild to moderate global NFB. Therefore the gain of the input diff pair and phase splitter is not of primary concern but linearity and speed. On the other hand it’s not the best configuration for class AB operation. I’m very interested to hear other’s experience if anybody has already tried class A of this topology, it would be very helpful if he/she shares the experience. Chip |
#50 |
Sadly, to my knowledge there is nothing quite like the 2N6658 or equivalent amongst the current production MOSFETs. One possibility would be to look at Toshiba audio MOSFETs or Hitachi laterals but use them in class A as their treshold voltage is far too low for class AB implementation using this topology - since the voltage swing at the MOSFET gates is centered around the midpoint defined by half of the diff. driver stage tail current. This works very well for high treshold high gm MOSFETs because a 0V to 2x(treshold) swing is usually actually far more than is needed for full output.
With Hitachi laterals, for instance, Vgs required for maximum current is 8 times that of Vgs at around 100mA current. Assuming we want maximum Vgs from the driver to get us the maximum output current through the MOSFET (~7A), half of that being the quiscent state, puts the MOSFET bias current well into the ampere range. Not quite class A but the difference is negligible - one half of the PP output stage will be conducting around 6A current when the other half turns off. Of course, this may be just what is needed in a particular application ![]() However, since the max Vgs we are talking here is around 8-9V, the driver and preceeding stages need to have a higher positive supply than that of the output stage, for best output swing. |
| Help needed! strange sound from nmos quasi amp | sanju21 | Solid State | 10 | 24th April 2012 09:03 AM |
| Schematic for Siemens F2a tube amp | MarW | Tubes / Valves | 7 | 12th August 2011 07:33 AM |
| Wildcard Power Amp dev. thread (SMD, Quasi NMOS, IRFP260, digital bias) | danfo098 | Solid State | 2 | 16th May 2011 08:57 PM |
| Need assistance for additional devices in DC detect for Quasis NMOS 350 Amp | qsa | Solid State | 1 | 22nd November 2008 10:43 PM |
| WTB Phillips B406 & Siemens Ba | panos29 | Swap Meet | 0 | 22nd September 2006 08:26 AM |
| Page generated in 0.13401 seconds (86.08% PHP - 13.92% MySQL) with 11 queries |
