How to identify a quasi-complementary amplifier? is it it contains 4 transistors 2 in 1 pair. And each pair is in complement? Does anyone can share some info about quasi-complementary amplifier?
thank you. |
#2 |
All output devices are the same type and number.
Either all npn, or all pnp. |
#3 |
I believe its common to find all NPN as outputs due to PNP's being difficult to make in the early to mid 70s.
#4 | |
This is a good question.
I don't think so. I call only such output stages as "Quasi complementary", if it looks like PP true complementary buffer except the lower last power transistor. This means for me, that the upper halve of PP buffer looks like a darlington and the lower looks like a sziklai (CFP) darlington An complete overview of topologies, where are only NPN-BjT's and N-CH MOSFET's in the last part of power buffer you will find here: Only N-Channel MOSFETs (NMOS); better Audio from non complements by Audio Power? also of interest in this case are some articles from the diyaudio member "X-PRO", e. g. Quasi or not Quasi - that is the question Last edited by tiefbassuebertr; 1st March 2010 at 10:10 AM. |
#5 | |
So quasi complimentary means the NPN's act as if they were complimentary. In reality that isnt quite true as one side has more gain than the other due to one side requiring an inverting driver which has gain, where as the other side is a simple driver buffer. I found the inverting side required a capacitor from collector to base on teh driver transistor to stop oscilation.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#6 | |
But the disadvantage there is the risc of oscillation of the buffer stages itself (not so by use of two stage, darlington for upper and sziklai darlington for lower buffer part. Only truly experienced (and unfortunately very few) developers (like Quad) achieve a design without any oscillation under any load condition. By many others there are oscillation and hum/buzzing effects through the sensitivity of parasitic influences. If I get such amp devices I must remove one stage in any cases, i. e. the reduce to a two stage PP buffer By the way, after right service and maintenance the Quad 303 is a very fine sounded amplifier, (much more better than the current dumping version Quad 405 and most true complementary versions). Only power stage versions with much more idle current trough the output can outperform the Quad 303 http://www.net-audio.co.uk/quad303upgrade.html Quad 33 and Quad 303 Quad 303 : Upgrade output stage to be fully complementary Quad 303 triple cascade Last edited by tiefbassuebertr; 1st March 2010 at 01:27 PM. |
#7 |
here basic articles:
#8 | |
Does this claim about quasi-complementary correct?
#9 |
| Another quasi-complementary design | quasi | Solid State | 628 | 12th April 2012 06:49 AM |
| 2N3055 inside - commercial famous amplifier models, quasi complementary power output | tiefbassuebertr | Solid State | 141 | 11th March 2012 11:57 PM |
| Quasi or full complementary. | pro | Solid State | 7 | 14th September 2004 09:26 PM |
| Page generated in 0.11219 seconds (79.07% PHP - 20.93% MySQL) with 11 queries |
