MosFet Relays - Page 10 - diyAudio
Old 15th April 2013, 01:56 PM   #91
It is a question resulting from my observation.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 15th April 2013, 02:18 PM   #92
doctordata's Avatar
The PV will take care off that .
Cheers ,
Rens
If you measure, you know; if you guess, you don't
Old 16th April 2013, 03:56 PM   #93
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Hello dhalbakken,
No, I have not tried that. Thanks for sharing your results.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 16th April 2013, 11:37 PM   #94
Thank you to everyone who posted ideas and schematics. I have located some VOM1271 that I can import into my country without excessive expense. I'll give the VOM1271 a go.
Old 1st July 2014, 05:48 AM   #95
doctordata's Avatar
Originally Posted by PaulBysouth View Post
The relatively new Vishay VOM1271 opto-photovoltaic device seems to be the best device to use for driving a pair of mosfet relay switches. It includes a fast turn off circuit. The opto LED needs to be driven between 10mA and 20mA for best results.
See attachment for the mosfet relay concept, and the vom1271 datasheet at http://www.vishay.com/docs/83469/vom1271t.pdf
Note that I haven't tried this circuit yet, though I have bought the bits.
Paul Bysouth
Hi Paul ,
Just interested if your relay works
Cheers ,
Rens
Old 4th July 2014, 01:18 PM   #96
Rens,
No I haven't built the mosfet relay yet! I've spent most of the year working on a 1000 watt class D subwoofer, so no time for my projects.
If anybody wants to use LTspice to simulate the vom1271 optovoltaic, I use either of the two following `simple' models below.
Some time ago (3 years ago I think), I built a number of prototype 250 watt power amps that used `mosfet relays' in the power rails. These used large FQA32n20c mosfets driven by a rather complex opto coupler based drive circuit, and where situated after the power supply Capacitors and fuse, and before 2*47uF caps on the power amp. If either fuse opened, then both `relays' opened and disconnected both power rails. Experiments with pulling a fuse out while the amp was working (a bit scary when you have +-70v rails) did not produce any audible thumps - the test signal just stopped!
Paul Bysouth
Old 26th February 2015, 11:17 AM   #97
Vlado70 is offline Vlado70  Slovakia
To output this works well, tested, you could not also be used to switch input, if it was overshadowed by against interference?
Old 23rd July 2015, 06:07 PM   #98
sajti is offline sajti  Hungary
I'm thinking to use MOSFET relay in my next PA amplifier. It's running +/-85V, and can drive 2ohms load as well.
My idea to use ASSR-V621 driver and IRFB4127 MOSFETs. My only question if the MOSFETs are strong enough (200V 76A) in case of DC failure...
Sajti
Old 23rd July 2015, 07:37 PM   #99
Banned
You have fuse on the rail?
I have SS relay at the output of my OPS board. I use TK72A12N1 120V, 4.5mohm max. almost 5 times lower than the one you choose. I even parallel two SS relay to get the total resistance of 4.5mohm max.
Old 24th July 2015, 06:00 AM   #100
As I'm still working on the amplifier, there is no problem to put or not put fuses...
Your mosfets looks Nice, however 120V is not enough to me. And 4127 has quite low on resistance, with small package, and moderate price.
My second possibility to use triac crowbar instead of relay.
Sajti
Output Relays Bonsai Solid State 641 Yesterday 06:41 PM
Relays siliconray Siliconray Online Electronics Store 0 12th October 2011 03:12 AM
Takamisawa relays samod Parts 1 14th June 2011 01:38 PM
Reed Relays Vs Standard Relays steevo Solid State 9 21st September 2009 05:08 AM
1 HP Relays jackinnj Swap Meet 0 15th November 2006 10:37 PM
Copyright ©1999-2017 diyAudio
