Old 10th November 2009, 03:27 AM   #1
AAK is offline AAK  United States
Default My new SymAsym PCB design Rev_1.3
Hi All,
I'm happy to say that after two-years away from this great hobby that my creative side has never felt better and I'm back and really happy to be able share my work once again with the members of this great forum.
My new PCB design is based on MikeB's conceptual circuit design found in post #2 of the following link,
Symasym - the sequel
and Roender's great work in completing, building, and testing the design.
Roender's work is found here.
Symasym - Roender Style
The new board measures 5”x3” like my original. This was no easy task considering the number of additional components I had to add in an already tight space.
In addition to adding components, the output transistors (OT) can now mount under the board so that a 3” heatsink can be used. The OT can also be extended 0.5” beyond each edge of the board like my original board design. I’ve added leds to each PS rail that also serves as a blown fuse indicator, and moved the AC inputs so that a terminal block can be used as well as fastons. I moved the Gnd terminal further from the PS caps to make it easier to access. I also added two full wave rectifier circuits before the PS caps on each edge of the board for those that would like to add a speaker protection or soft start circuit using the main transformer.
Enough said for the moment since it's getting late. I’ve attached the schematic that's currently implemented on my Rev 1.3 prototype board, and two THD plots at 100 watts into 8ohms, and 150watts into 4ohms at 1Khz. For the THD plots I've included the input signal's THD as a reference. It’s interesting that some of the harmonics improve over the original, something that also happens in MikeB’s original 5.3 design. The new design improves THD by a factor of about 2.5 to 3 over Mike's 5.3 design.
Al
Love when you can, Cry when you have to, be who you must, that's part of the plan.
Old 10th November 2009, 03:32 AM   #2
I think I forgot to upload. Here they are.
Old 10th November 2009, 03:42 AM   #3
Here's a pic of the PCB layout, THD plot at 150watt/4ohms, and the prototype boards.
Old 10th November 2009, 06:47 PM   #4
Hi Al
my hifi has a pair of your old boards doing sterling service. I have made several other power amps since making them, but the old Symasym boards still rule the roost. And some commercial power amps have also been found wanting. The thing I love the most is the bass - the amp seems so fast and dynamic. Consequently, if the new boards have improvements then bring 'em on. I can't wait to get my hands on a pair of boards. Thanks for all your hard work.
Aidan
Old 10th November 2009, 08:15 PM   #5
Hi Aidan,
I've built many amp kits and listened to some of the best high end amps and I agree MikeB's design using my original boards has held it's ground firmly. That said I must be crazy to do all this work to try improve on an already great design but that's just me. I love this hobby. And Mike’s and Roender’s work is was just to good to not try it.
Hopefully this week I’ll get around to doing a thorough A/B comparison to see how the sound of the new design stacks up with my old design. On paper the new design flat out measures better, but as you know it does not always translate to better sound. The nice thing though is that on the new board you can easily bypass components like the cascodes so that the circuit is more like Mike’s original design. Or you can try different combinations. You can even use Lateral Mosfet output transistors by simply using the jumpers provided on the board.
I also designed an external power supply board for those that would like to use a single transformer for two amps. And I just completed a dual output transistor version.
Best regards,
Al
Old 10th November 2009, 08:38 PM   #6
blueskynis's Avatar
Send a message via MSN to blueskynis Send a message via Yahoo to blueskynis
Hi AAK
Are you using single pair of output transistors with +/- 50V supply voltage? If so, then you are pushing to the limit those poor trannies.
Windows-free with Linux
== blueskynet.dyndns-server.com ==
Old 10th November 2009, 09:25 PM   #7
Piersma is offline Piersma  Netherlands
Piersma's Avatar
Default Resistive loading VAS
hi Al,
Congrats on your design, a beautiful compact designed lay-out.
You did omit de resistive loading of the VAS, is there special reason?
To gain more open loop maybe?
Did you do the boards yourself?
regards,
Old 10th November 2009, 09:27 PM   #8
Hi blueskynis,
I know I'm exceeding the SOA or close to it. I should of used a MJL3281/1302 pair but I didn't have any handy. Earlier iterations where tested with the MJL3281/1302, 2SK1530/2SJ201, and a pair of BUZ900/905.
Al
Old 10th November 2009, 09:36 PM   #9
Hi Piersma,
I omitted the VAS resistors because Roender determined that removing it improved THD in his testing. It also didn’t seem to make a whole lot of difference in my original board design, and it was confirmed by MikeB.
Yep, I did the board lay out.
Al
Old 10th November 2009, 09:46 PM   #10
Holger Barske's Avatar
Nice one.
No problem not to mount the driver transistors in the heatsink?
Best regards: Holger
www.holgerbarske.com
Symasym - the sequel anatech Solid State 496 27th May 2012 01:18 PM
Symasym PCB Khron Solid State 58 17th May 2012 07:18 AM
Troubleshooting your Symasym anatech Solid State 235 22nd September 2011 09:40 PM
symasym 5.3 parts 406vette Parts 2 17th February 2008 07:34 PM
symasym 5_3 boards traw Swap Meet 6 11th May 2007 09:41 AM
Page generated in 0.11849 seconds (79.89% PHP - 20.11% MySQL) with 11 queries
