Old 12th November 2009, 05:10 PM   #131
Steve Dunlap's Avatar
Hi Hugh,
First, I don't understand why you are having problems getting E-mail to me. I seem to be receiving E-mails from every one else, including those in other countries.
Either way, will it account for the reported lovely sound of this topology?
The difference in the perceived sound quality of my amps changed very much for the better when I changed over from the standard method of setting output bias to the method I use now. Distortion figures also improved. I think if I say more than that right now it would just be speculation on my part. Hopefully Andy will provide some answers.
Have you thought much about the large, compressive non-linearities due to Vbe creep and emitter resistor losses in the formation of odd order harmonics? If these could be reduced, presumably with error correction, would not the spray of odd, high order harmonics found in almost all Class AB output stages be drastically reduced?
Error correction, such as feedback, can (and does) reduce distortion in my amps. I built amps both ways. I prefer the NGFB sound. I did use feedback in my pro amps, and they sounded very good also. I'm not really driven to the pursuit of ever lower distortion numbers. I am happy that what I like sound wise also happens to measure fairly good. Here is the distortion numbers on the amp Andy is working on.I am content with numbers like these.
Fourier analysis for v(47):
No. Harmonics: 10, THD: 0.00248421 %, Gridsize: 200, Interpolation Degree: 1
Harmonic Frequency Magnitude Phase Norm. Mag Norm. Phase
0 0 -0.12172 0 0 0
1 1000 28.2861 -0.0092264 1 0
2 2000 0.000657583 71.3428 2.32476e-005 71.3521
3 3000 0.000128306 -151.08 4.53601e-006 -151.08
4 4000 8.10099e-005 100.802 2.86395e-006 100.811
5 5000 0.000170485 -0.65197 6.02717e-006 -0.64275
6 6000 4.31291e-005 83.065 1.52474e-006 83.0742
7 7000 6.33176e-005 43.2346 2.23847e-006 43.2439
8 8000 4.00605e-005 85.5068 1.41626e-006 85.516
9 9000 4.22854e-005 76.0533 1.49492e-006 76.0625
Old 16th November 2009, 07:55 PM   #132
It is now 14 days and counting. Maybe Andy has lost interest.
Old 16th November 2009, 09:02 PM   #133
AKSA is offline AKSA  Australia
Steve,
I'm confident he hasn't; he's either busy or still working on it. Andy is dedicated, I give him that.....
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 20th November 2009, 08:34 PM   #134
Hi Steve
It seems like Andy is busy with other things, so if somebody else would like to simulate the circuit I’m posting the models you are using.
Maybe you could confirm that these are the right models?
Cheers
Old 20th November 2009, 08:49 PM   #135
I will look those over. These are in the LTSpice format?
Old 20th November 2009, 09:18 PM   #136
I’m not using LTspice, so I don’t know if they will work in LTspice, but most of the simulator programs are based on the same algorithms so I see no reason why they shouldn’t work.
These are the models I’m getting when I open the”Export to Andy” file in Pspice.
BTW I have seen a lot of different models for the components you are using.
Cheers
Old 20th November 2009, 09:35 PM   #137
I looked them over and they seem to be correct. Maybe someone else can give it a try. It will be interesting to see the results. I trust they will use the schematic in the screen shot I attached in post 127.
Old 30th November 2009, 08:44 PM   #138
Originally Posted by stinius View Post
Hi Steve
Cheers
Hi stinius,
It has been 28 days since I posted the requested files. It looks like no one is going to use the models you posted, so I learned enough about LTspice to run the file Andy_C posted earlier. I have attached my results. I ran the file as posted by Andy, then just for fun, I ran it again with the bias resistor changed from Rbias to 4200 ohms. That is what the text in the lower left indicates the value Rbias is. I was not the least bit surprised to see that if you zoom in on the wave form and do the math, it appears the transistors do not turn off. That is what I have claimed all along. What does surprise me is that changing the bias resistor from Rbias to 4200 ohm changed the results. Does anyone have an explanation for why this happens?
Next I will edit Andy's schematic to the one I posted and try again. It may take me a while to do that. Please be patient.
Old 30th November 2009, 09:39 PM   #139
Interesting, Steve, something of an epiphany.
Your contention all along was correct, then? The outputs never turn off?
Could it be that the simulator has problems with driving the collector of a transistor?
Hugh
www.aksaonline.com
Old 30th November 2009, 09:39 PM   #140
That didn't take as long as I had expected. The attached file is the same schematic I posted in post 127. All resistor values are the same as in my posted schematic. I used the models that Andy included with the file he posted. The results are somewhat different from what I get with my sim program, but seem to be in my favor.
Symasym - the next generation (supersym) ostripper Solid State 253 18th August 2011 05:47 AM
boltar generation x old school badcompany Car Audio 2 27th July 2008 12:13 AM
generation x old school badcompany Pass Labs 0 25th July 2008 03:32 PM
philips cd 202 first generation daveyboy1964 Swap Meet 1 30th December 2007 08:40 PM
pwm generation sundeep2802 Class D 1 18th March 2005 05:39 PM
Page generated in 0.13954 seconds (81.00% PHP - 19.00% MySQL) with 11 queries
