#1 | |
I'm still at it ... trying for more power , better devices , and keeping it simple and reliable. While reading a little Douglas self (amp handbook), I ran across this statement :
This also brought up the question of model quality as the NJW21193/4's are newer to-3p ON devices and the models, (like the fairchild KSA's) seem to show the device in great detail (Cob , saturation "effects") versus "stupid" models - (mje340/50). It was cool that the simulation showed what Mr. self predicted ,..smoother Xover from 10k up , rounded corners in the Xover region at HF ,and a nice class A driver region (70ma average). Has anyone built something similar ??? I'd love to hear about it . OS BTW , WOW... what a improvement in the forum !!!
#2 |
Hi Os
That looks like a triple with the driver stage biased to the rails. It does show improved figures, scheme used by electrocompaniet and some others. Electrocompaniet goes further and uses a current source instead of resistors to bias which improves things further if youd like to try. Adreia Scafolli a Italian designer goes even further and biases the predrivers like that too, all show improvements THD wise, as for the sound youd have to try and listen to the sound of these schemes. The one you showed but using current sources gives a mighty kick in the bass but your amp better be quite fast or the bass will overwhelm. Carlos the destroyer didnt like it, I found no problems with it except the rest of the amp should be fast or the mids will sound slightly muddled. |
#3 | |
![]() That is a good sign !! Quote:
The FFT (attachment 1)shows the H3-7 almost goes away , even at full throttle. This looks a little like a diamond buffer in theory. I must say besides the already mentioned effects , the type 3 triple is far more stable as well. OS |
#4 |
Theres plenty one can do with output stages to improve the figures, use current mirrors instead of 2 current sources to get the currents in the collectors very close and it will show further improvement or even better use the current mirors but change the drivers to cfp s, I couldnt get this stable with BJTs but with mosfets it works great.
#5 |
This topology is much better than DB where a CCS limited driver current is available for driving the output BJTs
#6 | |
From my POV, this is the almost perfect class B output stage, as per Self OPS class definition. |
#7 | ||
Is this what you guys meant ??? (attachment 1)
![]() OS Edit : I thought it out , I could still use my 0281/0302's as the actual drivers, while using the mje's as separately heatsinked CCS's. That would make the CCS's independent of the main EF's Vbe.. Last edited by ostripper; 24th August 2009 at 06:34 PM. |
#8 |
Hi OS
I tried this topology "rail-to-rail", problem is requiring much current, you check Ib of output TRs, After you compare with Ib drivers. PS: I used for the pre driver... |
#9 | |
at 4r /400w (see attachment 1) , the CCS's (green/light blue) are steady at 35ma +-2ma -the mje15032/33's with a small PCB 10watt/c heatsink would be slightly warm at most (happy ,cool transistors). The drivers Ie (combined Ib of all outputs - Red/blue) is much higher , with a minimum 30ma ..peaking to 88ma. The drivers are outputs and will be on the same heatsink as the main outputs so this is not a real issue. (pink/grey) is just the current (Ib )to one pair of outputs. The THD improvement (attachment 2)is the best I've seen at 4R and even holds at 2R !! No wonder the Electrocompaniet amps have such high damping factors !! At these levels , a standard type 2 EF will drop dead (beta droop)... The Ib of the drivers is (attachment 3) is less than 1ma , no sweat for the ksa's (predrivers) ,no heatsinking would be required. OS OS |
#10 | ||
Banned
ostripper,
roender, Quote:
| need some pointers to find the right design | Lifthanger | Full Range | 33 | 6th August 2009 08:10 PM |
| n00b pointers and advice | Jonitus | Everything Else | 0 | 10th September 2008 08:47 PM |
| Smaller Mixer Pointers? | BearJ | Analogue Source | 0 | 8th August 2004 06:43 PM |
| preamp pointers | name773 | Solid State | 1 | 24th April 2004 05:43 PM |
| Switches - Dual Triple Pole, Triple Throw | jackinnj | Swap Meet | 0 | 27th January 2003 07:18 PM |
| Page generated in 0.13232 seconds (78.36% PHP - 21.64% MySQL) with 11 queries |
