#2 |
Dont think it will work, vas biasing currents are undefined by using the mirrors, do a search here for Randy Slone s designs for more details.
#3 |
It will not work. The VAS standing current will not be well defined when using current mirrors. Try searching G.Kleinschmidt symmetrical design posted here on forum.
#4 |
Ok, thanks for confirming my doubts. It worked when I first simulated it but after reading your comments I tried doubling the supply voltage and the quiescent current through the output transistors increased from ~70mA to ~700mA.
I modified the circuit to this: There should be no further problems with this modified circuit right? |
#5 |
How suceptible to R5 R12 mismatches is the output bias current and output offset voltage? (change one to 101 ohms)
#6 |
The output bias current changes about 1mA/ohm and the output offset 1mV/ohm if I change R5 or R12.
#7 |
OK, no worries there.
#8 |
Keep the emitter followers on the VAS stages. Also consider cascodes.
#9 |
where are you getting your resistor values from?
E24 values are common. E48 and E96 values are difficult to source at sensible prices.
regards Andrew T. |
#10 |
I just pick the values (from thin air
) then I source the closest/best compromise mostly from farnell.But don't get hung up on the values in the above modified schematic I will most likely change them. |
| Need comments on amp design | mightydub | Solid State | 28 | 24th December 2008 02:01 AM |
| My first amp design - comments | blueskynis | Solid State | 36 | 26th March 2008 04:38 PM |
| need comments on amp design | metebalci | Tubes / Valves | 0 | 10th September 2006 09:03 PM |
| Comments on TL design, pls | Jorge | Multi-Way | 2 | 9th June 2005 04:05 PM |
| Comments on this design? | G | Tubes / Valves | 0 | 16th October 2003 06:09 PM |
| Page generated in 0.08429 seconds (86.39% PHP - 13.61% MySQL) with 11 queries |
