Hello,
This is my first project built without a kit, and my fourth ever. Here is the link: http://diyaudioprojects.com/Solid/ZCA/index.htm I'll attach the amp schematic on this post, and the power supply schematic on the next one. The above web site has been unavailable at times the last few days. I would be grateful for any answers or advice. --One resistance is shown as 15R/40W, could I use four 60 Ohm, 10W resistors connected in parallel here? --Where the wattages of the resistors are not specified, does it matter, or would a half or quarter watt be ok? --What voltage should the capacitors be, or does it not matter? --How important is it to match the exact capacitance on the schematic, is it ok to go a little higher or lower? --Is it ok to connect smaller caps in parallel to get larger cap values? |
#2 |
Here is the Power Supply schematic.
--Same questions about the caps, would it be ok for example to replace the low ESR 450uF cap with a low ESR 470uF? --And do the cap voltages matter? --What specs to I look for in a transformer for this power supply? Thanks |
#3 | ||||||
hi Kinnja
before you decide on this design, are you aware this thing outputs somewhere between 5-10 watts of power? That means you need really efficent speakers to get the best out this amp. Quote:
good luck and hope it sounds good:-) |
#4 |
Kinnja,
I believe there is a mistake on the power amp schematic. The polarity of 33uF tantalum cap is backwards. The positive connection of the cap should connect to the 100k wiper. You should email (Mark Houston) to confirm this. Tom |
#5 |
I think this amp actually only puts out 1w of power, at least that is what the Site says.....The Design is very simular to the Mosfet Headphone driver accept useing a Lateral Mosfet....
#6 | |||
#7 |
all that effort for 1 watt
#8 | |
One watt isn't much is it? The actual number should be around 5W. On the web page he says he burns up over 60W to get 5W Class A. |
#9 | |
I also noticed that the positive terminal of the speaker is connected to ground. If I build it as is, I guess I can get a cheap speaker, and stand clear of that cap when I plug it in. Hopefully only the cap would get fried. On the web site, he has an article by someone who built the amp, and he didn't say anything about any mistakes on the schematic though. http://diyaudioprojects.com/Solid/Cl...sfet/index.htm |
#10 |
Kinnja,
The schematic on the website looks correct now. (fixed?) The positive of the 33uF now goes to the 100k wiper. Tom |
| mosfet class a/ab amp | p robertson | Solid State | 30 | 9th February 2010 11:07 AM |
| NX400 - 400W RMS@4Ohms Lateral Mosfet Power Amplifier Module by Class-D for sale | magnum_1 | Swap Meet | 16 | 13th June 2009 03:59 PM |
| Small Power D class MOSFET Amplifier Needed!! | Kazus | Class D | 8 | 12th March 2009 02:58 PM |
| Class Mosfet power amplifier circuit | Agus Widarto | Pass Labs | 16 | 18th February 2008 04:06 PM |
| JLH Class-A in a with MOSFET's | tschrama | Solid State | 3 | 10th February 2002 03:23 PM |
| Page generated in 0.12539 seconds (79.89% PHP - 20.11% MySQL) with 11 queries |
