Old 30th January 2008, 04:03 PM   #251
roender is offline roender  Romania
roender's Avatar
Amplifier case is almost ready!
Hellp me friends, shall I make the front plate and volume button anodized black?
Old 30th January 2008, 04:05 PM   #252
roender's Avatar
View from inside
Old 30th January 2008, 04:08 PM   #253
roender's Avatar
Mounting support for volume pot
Old 30th January 2008, 05:29 PM   #254
DRZ1 is offline DRZ1  Canada
Roender , very good job.
why not mounting the pot at the back and use a extention rod ? I do it like that with my Symasym.
Personaly i prefer black.
Old 30th January 2008, 07:04 PM   #255
roender's Avatar
Thank you Denis
Your case is very nice too.
I will put a DAC inside, monted in front of the case and very close to the volume pot.
This amplifier will have digital inputs only.
Mihai
Old 30th January 2008, 07:55 PM   #256
Ohhh, i see.
Old 2nd February 2008, 08:46 PM   #257
Hello everybody, my first post on this forum!
@roender I'm mesmerised ! Congratulations for an excellent amp, I'm really impressed by your skill and knowledge!
I have a few questions about your design. I hope they don't sound stupid, but i am a newbie in electronics and I have quite a hard time trying to understand how amplifier work. So why have you chosen higher supply voltages for the input stage than for output stage? Why is the current source Q17,D8 and R20 connected to the anode of D17(and not the positive supply rail)? What is the purpose of C7?
Thanks in advance for the answers. Maybe you could point to me some good sources of information about amplifiers and electronics.
Once again I congratulate you, and I wish you good luck on your projects!
Old 3rd February 2008, 01:56 PM   #258
roender's Avatar
Hi Emanuel,
The only stupid question is the one you don't ask.
Are you doing EE at Politehnica Bucuresti?
Way bigger rail voltage in front than in output stage? It's a folded cascode design, with limited voltage swing in "VAS" at cascode base reference voltage.
"Why is the current source Q17,D8 and R20 connected to the anode of D17 ?
That's a very good question! You are the only one who see that and ask about reasons.
The firs stage is a class A stage and I like to have symmetrically currents in every class A stage I design, with as little as possible return currents to ground, to keep the zero reference clean.
The role of C7 is to slow down voltage response in output stage bias circuit.
Mihai
Old 3rd February 2008, 05:36 PM   #259
destroyer X's Avatar
Default You amplifier sounds so good that i would be happy with them even inside those
Card boxes used for shoes.
Carlos
Audiophoolery; http://www.youtube.com/watch?v=m7ERMu825m4; Dx Super Etching; http://www.youtube.com/watch?v=WED3Bvmxepk
Old 3rd February 2008, 05:51 PM   #260
Thanks for the answer! I see that your design is more clever than i thought! I really like your way of implementing current sources. Fancy that! . Now i see that a good amplifier has a lot of "secrets" and much thinking and work behind. Keep up the good work!
About Politehnica Bucuresti, you came close. I'm doing Automatics.
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 27 9th July 2010 10:56 PM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
Copyright ©1999-2013 diyAudio
