Old 16th November 2007, 09:35 PM   #91
johanne is offline johanne  Germany
hello roender
great design, and i´m in phase with carlos!
please tell us how to buy the thermal traks.
regards
Ralf
Old 17th November 2007, 10:52 AM   #92
roender is offline roender  Romania
roender's Avatar
Originally posted by johanne
hello roender
regards
Ralf
Thank you Johane.
You can order sample from ONsemy and you have to pay for transport only:
http://www.onsemi.com/PowerSolutions...do?id=NJL0281D
http://www.onsemi.com/PowerSolutions...do?id=NJL0302D
Or you can buy from Digikey.
Mihai
Old 17th November 2007, 10:58 AM   #93
roender's Avatar
Default Re: I am learning a lot, in special because of Roender and Hugh
Originally posted by destroyer X
... and also because Roender's superior design i will try this one in January.
Thanks,
Carlos
Originally posted by sunrise
Dear Roender,
can we have some parts info related your "shunty" psu ??
please?
thanks
Dear Carlos,
I am glad to hear that!
You will have my full support because this amp is not ease to build.
Dear Sunrise,
The BOM and construction details will be ready tomorrow
Mihai
Old 17th November 2007, 01:46 PM   #94
sunrise's Avatar
Send a message via ICQ to sunrise
Default Re: Re: I am learning a lot, in special because of Roender and Hugh
Originally posted by roender
Dear Sunrise,
Mihai
thanks
when you burn it - burn it good
Old 17th November 2007, 06:47 PM   #95
thanks for info, so on not off
regards
Ralf
Old 18th November 2007, 02:13 PM   #96
roender's Avatar
RMI-FC100 amplifier BOM
Resistors and capacitors values are printed on schematic.
http://www.diyaudio.com/forums/attac...mp=1194852081&
All resistors are 0.6W metal film with exception of
R3, R4, R10, R33, R39, R47: 2W metal film.
R8, two 10ohm 0.6W metal film resistors conected in parallel
C8, C9, C18: silvered mica or styrofelx or ceramic NP0
C1, C10,C11: WIMA MKS4 63V
C2, C7: WIMA MKS4 250V
C21: 16V LOW ESR (Panasonic, Rubycon)
Biggest capacitors on PCB: 4 x SAMWHA 10.000uF/50V HC series *
Capacitors colse to power BJTs: 4 x Panasonic 1000uF/63V LOW ESR FC series *
*- see amp pcb http://www.diyaudio.com/forums/attac...amp=1194895504
D1, 1N4148: 1W glass case
D2, D3, D8: Green LED type LT433B or any other rectangular LED with Vf>=1.9V at If=5mA
D7, D6: BL-R5122B.RED or any other rectangular red LED
J1, J2: 2SK170BL with Idss >= 9mA
Q6, Q7, Q9: BC550C
Q11, Q13, Q17: BC560C
Q8, Q15, Q18, Q19, Q21: 2SC3423Y
Q10, Q14, Q16, Q20: 2SA1360Y
Q1: MJE15034
Q3: MJE15035
Q2, Q12, Q25: NJL0281D (prefered) or NJL3281D
Q4, Q5, Q27: NJL0302D (prefered) or NJL1302D
The following BJT peers must have hfe as close as possible:
Q21-Q18
Q11-Q13
Q6-Q7
Q14-Q16
Q19-Q20
Q1-Q3
The folowing power BJT must have the same Vbe +/- 1mV (only between the same type NPN/PNP) and all must have hfe as close as possible:
Q2-Q12-Q25-Q4-Q5-Q27
J1 and J2 must have the same Idss>=9mA and must have the same Vgs +/- 1mV at Id=6.25mA
Old 18th November 2007, 02:50 PM   #97
roender's Avatar
RMI-FC100 frontend PSU BOM
http://www.diyaudio.com/forums/attac...amp=1194852836
R1, R2: 2R2
R3, R4: 33R
R5, R6: 11k
R7, R8, R9, R10: 2k
R11, r12: 560R
C1, C2, C3, C4: 10nF/100V ceramic
C5, C6, C7, C8: 2200uF/63v
C13, C14: 100uF/50V Low ESR
C9, C10: 2u2 WIMA MKS4 63V
C11, C12: 2n2/100V ceramic NP0 or CG0
C15, C16: 470nF/250V MKP or MKT
D1, D2, D3, D4: FR107
LED1,2: Green LED type LT433B or any other rectangular LED with Vf>=1.9V at If=5mA
D7, D8: Z39/1W zener diode
T1: BD140
T2: BD139
Q2, Q3: BC550C
Q4, Q5: BC560C
Q6: MJE15034
Q7: MJE15035
Old 18th November 2007, 05:48 PM   #98
roender's Avatar
Starground connection to main capacitors
Old 18th November 2007, 05:51 PM   #99
roender's Avatar
NFB connections and starground point
Old 18th November 2007, 05:53 PM   #100
roender's Avatar
One NJL diode must be bypassed
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
lucylu
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 27 9th July 2010 10:56 PM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
Page generated in 0.12594 seconds (81.16% PHP - 18.84% MySQL) with 11 queries
