hi everybody..i was looking for 2sj162and 2sk1058 transistors for a long time in my country..and at the end i found them..i measured the gate-drain voltage of them..it is 0.57v and the other one is 0.63 v ..now some people say it is not necessary to match these lateral mosfets..what do you think about them?should i match them?i want to make a class a amp..i need to make a good pcb for it..it is very difficult to make a class a amp..every component have to be matched..so what do you think everyone?should i match 2sj and 2sk?
#2 | |
depends ....... show us schematic and than we can tell you for sure ....... in any case - if you match them,you'll have better symmetry ; in case that you must use multiple pairs , matching is necessary
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
for example this circuit..
and i need a good class a pcb..i am working and i have not much time to draw it..would you send me a class a pcb ..will work at + -35 volts? |
#4 | |
ya nutz ? ![]() that's my circ - in fact my friend Oly made this little schematic . you didn't follow exact thread where this is posted ; somewhere in start of Babelfish J thread it's intended for IRF150 (or IRFP150 , whatever ) and his cousin IRF(P)9150 ; matching isn't so crucial there . you can use 2SJ and 2SK with slight recalculation of drain resistors of Q1 and Q2 . and - it isn't too wise to make it with more than 2x 25V I have somewhere graphical files for that pcb ...... is that what you need ? EDIT: now I remember that Turks slaved Serbs for 600 yrs........ I will not help you with this ......... hehe, just joking,off course
#5 |
yes i need a schematic and pcb..my friend made a class a amplifier works at+-24 volts..it is working with irf540 and 9540..but the current was not stable enough..i will use 2sj162 and 2sk1058..if you send me schematics and pcb i will be happy
#6 | |
well - for stability you need to place input jfets in tight position , same as on this pic:
#7 |
that's last , tested schematic
#8 |
yes i know it..my friend is tieing transistors like this..dont you have a pcb that works in Ares ?
#9 |
and that's what I have regarding pcb ;
now you need just little work in some graphic progie ....... dunno is it scaled.......
#10 |
thank you
| 2SJ162-E and 2SK1058-E | 1965GTO | Vendor's Bazaar | 4 | 26th March 2012 01:38 PM |
| Anyone know where to get 2SJ162/2SK1058 | fossil2k | Solid State | 8 | 17th March 2008 12:07 PM |
| 2sk1058/2sj162 Fs | sandyhooker | Swap Meet | 3 | 12th March 2008 04:50 PM |
| 2sk1058 / 2SJ162 - 4 of each - aus only | mikefromaus | Swap Meet | 0 | 24th January 2008 01:27 PM |
| Fake 2SK1058 or 2SJ162? | ShinOBIWAN | Solid State | 8 | 19th March 2005 04:24 AM |
| Page generated in 0.10499 seconds (81.50% PHP - 18.50% MySQL) with 11 queries |
