Spice simulation
If anyone wants to use
Exicon Lateral MOSFETs
you should download Christers submitted ZIP file
from this post:
http://www.diyaudio.com/forums/showthread.php?postid=362324#post362324
Exicon can be found with datasheets at http://www.profusionplc.com/
Profusion has got very good other transistor, too.
Like some excellent SANYO driver transistors in TO-126 and TO-92
with Low cob capacitance = 2 - 3 pF
2SB1144 OTHER -100V -1.5A 100 10W 100MHz TO126ML PNP
2SD1684 OTHER 100V 1.5A 100 10W 120MHz TO126ML NPN
KSE340 OTHER 300V 0.5A 100 20W 10MHz TO126 NPN
KSE350 OTHER -300V -0.5A 100 20W 10MHz TO126 PNP
2SA1668 SANKEN -200V -2A 60 25W 20MHz FM20 PNP
2SC4382 SANKEN 200V 2A 60 25W 15MHz FM20 NPN
2SA1208 SANYO -160V 0.07A 250 0.9W 150MHz TO92-EXT PNP low Cob
2SA1209 SANYO -160V -0.14A 200 10W 150MHz TO126 PNP low Cob
2SA1606 SANYO -180V -1.5A 45 15W 100MHz TO220-ISO PNP
2SB1037 SANYO -150V -1.5A 50 30W 8MHz TO220 PNP
2SC2910 SANYO 160V 0.07A 300 0.9W 150MHz TO92-EXT NPN Low Cob
2SC2911 SANYO 160V 0.14A 200 10W 150MHz TO126 NPN Low Cob
2SC4159E SANYO 180V 1.5A 45 15W 100MHz TO220-ISO NPN
2SD1459 SANYO 150V 1.5A 50 30W 8MHz TO220 NPN
2SA1837LB-TF3T UNISONIC -230V -1A 180 20W 70MHz TO220-ISO Complement to 2SC4793
2SC4793LB-TF3T UNISONIC 230V 1A 180 20W 70MHz TO220-ISO Complement to 2SA1837
2SB649A UNISONIC -160V -1.5A 160 20W 140MHz TO126 PNP
2SD669A UNISONIC 160V 1.5A 160 20W 140MHz TO126 NPN
BD139-16 UNISONIC 80V 1.5A 100 12.5W 190MHz TO126 NPN
BD140-16 UNISONIC -80V -1.5A 100 12.5W 190MHz TO126 PNP
hey guys, I have a few newbie questions I hope you don't mind:
1) When simulating THD of an amplifier, do we simulate it at the close loop gain we normally use or do we simulate it at unity gain instead?
2) I'm not sure if I simulated correctly, but using TINA SPICE here's how I do it:
-Insert an input voltage of 1V Sin wave at 1000Hz
-then run fourier analysis.
3) Anyone here has commonly used LEDs meant to bias the folded cascode stage?
Aksa,
Here you go
http://www.onsemi.com/pub_link/Collateral/MJE15030.LIB
http://www.onsemi.com/pub_link/Collateral/MJE15031.LIB
************************************** * Model Generated by MODPEX * *Copyright(c) Symmetry Design Systems* * All Rights Reserved * * UNPUBLISHED LICENSED SOFTWARE * * Contains Proprietary Information * * Which is The Property of * * SYMMETRY OR ITS LICENSORS * *Commercial Use or Resale Restricted * * by Symmetry License Agreement * ************************************** "* Model generated on May 23, 02" * MODEL FORMAT: PSpice .MODEL Qmje15030 npn +IS=3.894e-11 BF=312.524 NF=1.0979 VAF=9.9963 +IKF=0.796201 ISE=2.37397e-09 NE=1.94897 BR=0.14246 +NR=1.64791 VAR=99.9749 IKR=0.00539895 ISC=2.33175e-09 +NC=2.79024 RB=267.202 IRB=9.99994e-13 RBM=0.299835 +RE=3.04316e-05 RC=0.252928 XTB=0.1 XTI=3.92812 +EG=1.05 CJE=2.42998e-09 VJE=0.794171 MJE=0.569313 +TF=1.87986e-09 XTF=1000 VTF=1835.34 ITF=270.188 +CJC=2.43127e-10 VJC=0.4 MJC=0.361453 XCJC=0.802892 +FC=0.8 CJS=0 VJS=0.75 MJS=0.5 +TR=9.86194e-06 PTF=0 KF=0 AF=1
************************************** * Model Generated by MODPEX * *Copyright(c) Symmetry Design Systems* * All Rights Reserved * * UNPUBLISHED LICENSED SOFTWARE * * Contains Proprietary Information * * Which is The Property of * * SYMMETRY OR ITS LICENSORS * *Commercial Use or Resale Restricted * * by Symmetry License Agreement * ************************************** "* Model generated on May 23, 02" * MODEL FORMAT: PSpice .MODEL Qmje15031 pnp +IS=7.17489e-11 BF=457.169 NF=1.11376 VAF=6.01557 +IKF=0.345808 ISE=1e-08 NE=2.18567 BR=0.247882 +NR=1.39549 VAR=60.1557 IKR=0.0263893 ISC=1e-16 +NC=2.89486 RB=2.29208 IRB=0.0114006 RBM=0.000102795 +RE=0.00815557 RC=0.0407779 XTB=0.1 XTI=0.1 +EG=1.05 CJE=1.64037e-09 VJE=0.819491 MJE=0.537987 +TF=1.60991e-09 XTF=180.82 VTF=1.16561 ITF=6.50499 +CJC=4.82516e-10 VJC=0.4 MJC=0.374287 XCJC=0.786653 +FC=0.712788 CJS=0 VJS=0.75 MJS=0.5 +TR=3.32795e-08 PTF=0 KF=0 AF=1
Many thanks TzeYang,
Much appreciated!
However, I can confirm it does not work well; I've found that if Ic and Vceo come up on these models as zero, then the model is bad. Certainly the results in my simmed amp are not appropriate; a 5401/5550 gives near perfect results notwithstanding poor current capacity, but these models give sub par gain overall, which is not good.
The usual turf wars between manufacturers, it seems.
Anyone have a model for 15030/31 that works well?
Hugh
Hi Hugh,
Glen and OS have both seen problems with the MJE15030/15031 OnSemi models. Here is the part of the Frugalamp thread where it's discussed. I agree with jaycee that Fairchild's models tend to be pretty good.
You might try the 2SC4793/2SA1837. I created these. They shouldn't be used above 1A though.
Edit: Welcome to the SPICE world Hugh!
.MODEL Q2SC4793 NPN (
+ IS=1.8E-09
+ NF=1.43
+ BF=146.38
+ VAF=273
+ IKF=2.6
+ NK=0.95
+ ISE=6.286997E-10
+ NE=2.223629
+ BR=4
+ NR=1
+ VAR=20
+ IKR=1.05
+ RE=0
+ RB=1.7
+ RC=1.25
+ CJE=5.96964E-10
+ VJE=1.1
+ MJE=0.5
+ CJC=5.78E-11
+ VJC=0.3
+ MJC=0.3
+ TF=1.22678E-09
+ FC=0.5
+ ITF=10
+ XTF=99.52253015
+ TR=983N)
.MODEL Q2SA1837 PNP (
+ IS=2.39372559E-10
+ NF=1.304015937
+ BF=300
+ VAF=273
+ IKF=2.087725944
+ NK=0.94719458
+ ISE=1.46829699E-11
+ NE=1.526663542
+ BR=4
+ NR=1
+ VAR=20
+ IKR=1.05
+ RE=0
+ RB=1.8
+ RC=1.65
+ CJE=4.7407E-10
+ VJE=1.1
+ MJE=0.5
+ CJC=8.6700E-11
+ VJC=0.3
+ MJC=0.3
+ TF=1.642191E-09
+ FC=0.5
+ ITF=1.076260106
+ XTF=5.868994022
+ TR=1.38U)
Thank you Andy,
Much appreciated!
I have found it useful already; it's compressed development time considerably, enabling me to home in on stability issues very quickly. The open loop techniques have been very useful establishing accurate levels of feedback, nested and global, and this too has been a great advance.
It tells me nothing of the sound quality, of course, but I can get through the engineering issues much more quickly.
Thanks again, I have your 4793/1837, find them very good indeed, and use these as drivers in some of my other amps.
Hugh
By aska - I've found that if Ic and Vceo come up on these models as zero, then the model is bad
Not always true , hugh... The ( ) header is what gives LT
the data to place device info in the listing. All the generic
ones that come with LT have it , but some (almost all)
of the 3rd party .models omit it.
The fairchild models have extra data and show more
realistic conditions within a design..
As a test I designed a new amp with MPSA 94/44's
using the old models .I had a easy time getting it to be
stable, but when I switched to the new fairchild KSP94/44
(2007 models) ,my triple OPS oscillated and saturated.
(in a quite realistic way 😀)
Thank you andy for new 4793/1837's ,old japanese models
I have are much less verbose (data wise).
OS
By aska - most fires now under control, cleanup beginning. 173 dead, 700 homes destroyed within 150 mile radius of Melbourne. Tragedy.
Hope they catch the SCURVY B@$$tards that set some of them..
That's very informative, much appreciated.
If you want to correct this small inconvenience ,here is an example...
.MODEL KSP44 NPN
+ IS=2.4446E-13 BF=184.79 VAF=100 IKF=9.6380E-2
+ ISE=2.8775E-12 BR=0.17129 VAR=100 IKR=2.2351
+ ISC=6.0845E-10 NC=1.5000 RE=0.1 RB=4.7095
+ RC=2.7922 CJE=1.0100E-10 CJC=1.9010E-11 VJC=0.66207
+ MJC=0.40238 TF=1.1000E-8 XTF=10 VTF=10
+ ITF=1 TR=3.86493E-5 FC=0.5 XTI=3
+ EG=1.11
+ Vceo=400 Icrating=.3 mfg=fairchild
The last 3 entries is the data the LT device listing reflects
(+ Vceo=400 ,Icrating=.3 , mfg=fairchild)
It works good ..as reflected here: (attached)
Hello
I would like to know, as you are to measure FFT in LTspice-IV, is there any setting to set simulation?
I put a source in 1KHz and only one resistor, and the result 3,1% distortion 😕
I could get the graphics of the harmonic only EX: 2nd in 20-20 KHz?
Thank's
Good advice.. turn off all compression..🙂
I was just doing some FFT's and noticed this thread..
Andy C. has a good way to do it.
Add this as a general LT comment:
.param timestep 1m/65535
.tran 0 10m 0 {timestep}
.options plotwinsize=0
.four 1k
Notice the {timestep}....
add this to the AMPLITUDE of your signal source;
{sqrt(2)}
The "2" will drive the amp to about 30 db , near full power
depending on the amp. (A '1" in the equation will give the 20db
below)
simulated by itself the signal source has noise level of -200db
, Much better than a "strait up" generator.
here is what you might see (-110db .0001%)😀
os
Thanks for information
Experienced both forms, the first simulation, Total Harmonic Distortion: 2.12%
then enable ASCII data files 😕 Total Harmonic Distortion: 0.77%
I be much distortion for a signal "pure" sine
Netlist:
V1 N001 0 SINE(0 1 1K)
R1 N001 0 1K
.four 1K 9 V(N001)
.tran 0 1 0.01
.option plotwinsize=0
.backanno
.end
