If you were one of the first to download Page1 & 2, I just updated page 2 as their was a minor error
<i>Z=R<sub>c1</sub> || R<sub>c2</sub>||R<sub>bb</sub>, where Rn is ...</i>
should have been:
<i>Z=R<sub>c1</sub> || R<sub>c2</sub>||R<sub>bb</sub>, where R<sub>bb</sub> is...</i>
Apologetically
James
should have been:
Apologetically
James
tiroth said:There is that funky || notation again. Weird.
Correct me if I'm wrong, but is this right?
A||B = (AB)/(A+B)
The rule for parallel devices, resistors etc.
Jfet constant current source
Great ap note on Jfet CCS.
http://www.vishay.com/document/70596/70596.pdf
H.H.
H.H.
What CCS do you use, and what for? I see that Morsel is working on one to load an opamp. How's that one coming? That one's jfets, right? When you use one in a project, is it an afterthought? If not, is the main PCB designed with it, or is it a replacement for a resistor?
As I've said before, I've drawn a few. They all use BJTs. I print 'em by the dozen. I don't want to believe that my fascination (read: obsession) was a waste of time. Does anybody want to try a few?
The link doesn't work (anymore).
What was the name of the document, so I can search for it ?
http://www.vishay.com/docs/70596/70596.pdf
but you should always try the "Wayback Machine" http://archive.org/web/web.php
http://web.archive.org/web/20050528193956/http://www.vishay.com/document/70596/70596.pdf
but you should always try the "Wayback Machine" Internet Archive: Wayback Machine
Thanks, for the links, appreciated.
- Constant Current Source article (Old)
