about remaining payment
Hi Quanghao
It's very sorry to late to sent my remaining payment until now,it's very busy few months for work.
May I ask you some question:
1.When I paid payment,can shipping es9018DAC to me now or must be wait next GB?
2.My order total cost is $650,I had already paid $325,and I want to buy another one "The Kit IV stage" -->add $60 and give me a DAC shield-->add $5
and shipping choice2 VNPost -->add $100,so I will pay $490 to you,right??
ref:https://docs.google.com/spreadsheet/ccc?key=0AtSq4Ehd3GvbdEpjUlZIM2dZdmhEUi1HRy1LaVhBZFE&hl=en#gid=0 list20
please kindly reply to me,thank you very much
Antony Shih
Hello Quanghao, Sorry for late to sent my remaining payment,now I want to ask the "The Kit IV stage" can order one again?(I mean I want to buy another one "The Kit IV stage" ) Have I a chance?
Thank you.
Antony Shih
yes, you have it!
thanks
Hi Quanghao
Antony Shih
Hi, Should I get Pickit2 or Pickit3?
PICkit 3 In-Circuit Debugger
There are also a starter kit at a bit extra. or express kit? Please advise. Many Thanks
this
Microchip Pickit 2 Pic Programmer Debugger | eBay
Pic kit 3 is the new version but I don't know if this run good.
A lot of tin and heat well. I used 2 soldering irons.
A lot of tin and heat well x 2
Firmware 57a Error
Firmware 57a Error (2013-09-29)
http://www.diyaudio.com/forums/quan...018-full-assembled-board-174.html#post3649245
1. 352.8Khz Display error.
2. Setup Menu -> Phase control function doesn't work.
1. Solved - here 58a (352.8Khz -> 352 KHz - not tested)
2. It is not possible to change the phase for USB input
Hi Quanghao,
Any news about transformer output pcb?
My personnal board (See attached file).
Br
Jacky
Why not just use a Vero board for this simple circuit ?
It's just my realization , just to give you ideas and many other solutions are possible.
Br
Jacky
Hi Quanghao,
yes, i need put pcb for test someday!
Hi Quanghao
Antony Shih
Hi Quanghao
Please reply for me,thank you.
Just want to share a few pictures of my DAC sitting in a China made stock case....
Nice setup!
Noticed that you have cut the AES push pin... without the designated tool, it really is a pain to take out! I've decided not to put it back after it was out.
Consider using an EMI filter to suppress power noice?
Nice setup!
Just try-in only, the AES pin shall be put back once the wiring is complete. Some folks say EMI filter does no good to SQ, may try compartmentalization later.
Hello all
I have been very busy so have only just begun trying to assemble my DAC. It is an early model so I will have to make all the modifications. Never mind, this is DIY so its all part of the fun LOL
I have one question (I promise I have searched and in fact have read through the whole thread to get up to speed). I am trying to upgrade the Amenero firmware as per instructions on here:
ES9018 USB DAC - Hi-Resolution System
But it is not clear to me where to obtain latest firmware (1.58?)
I am running ConfigOEM109.exe, 'Firmware Update' tab.
The only firmwares listed in the drop down list (next to 'Download firmware' button) are
firmware 1074
firmware 1080
bitclk_test
So where do I get firmware 1.58?
Cheers
firmware 1074
firmware 1080
bitclk_test
Cheers
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
