SG3525 for Inverter
SG3525 for Inverter
Old 25th March 2007, 04:40 PM   #1
xpikon is offline xpikon  Pakistan
Default SG3525 for Inverter
Hi 2 all.. i m in my final sem of electronics engr.
My project is to generate electrical power using solar energy.
I want to have an inverter circuit (for 500W, 220VAC) using SG3525. The one I got is from an Yougoslavian website. The discription is written there but I cant understand that neither can translate through an online web translator. I am attaching that circuit in this post. So if any1 can understand it plz help to me to get it. Also if any1 have better circuit than it (but in working condition) so plz provide me.
Old 26th March 2007, 01:11 AM   #2
ifrythings is offline ifrythings  Canada
ifrythings's Avatar
Here's a working one all you have to change is the winding ratio to suite your needs.
The one above looks ok but with out trying it I can't tell you for sure.
Old 26th March 2007, 08:16 AM   #3
Thats i have seen b4...but it is ckt for SMPS....
See, what i m doing is getting 12V DC from solar pannel...then charge the battery (Deep-cycle) and then input the battery's output voltage to an inverter(500W,220VAC)...
For this kind of scenerio....if u can give me ckt...then plz do it....
The ckt which i attach in the above post is taken from
http://www.mikroelektronika.co.yu/do...oj/1broj12.htm
but as u can see there it is not in english.....i know its not ur job but if u (or any1) can able to translate that language into english plz tell me that way.......coz they have explain it also...
hope u now understand the situation
Old 26th March 2007, 01:51 PM   #4
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Xpikon:
Here is a schematic of a 2.5kW DC-AC Inverter. This is nearly the same basic schematic used in almost all DC-AC Inverters. Obviously, there are always small variations. As you can see, there are actually two stages: the 12V to 165V DC-DC boost converter, and the 60Hz Modified sinewave H-Bridge.
For your applications, you will need to connect in series, all 8 of the secondaries from the DC-DC converter section (resulting in ~330VDC) , changing the diodes to 800V devices, & filter caps to 400V units. Then, you will adjust the frequency from 60Hz to 50Hz.
As mentioned, this is a 2.5kW inverter. At 120VAC, this is just over 20A, but for 240VAC, this should be ~10A, enough for your stated needs.
Hope this helps you in the right direction.
Steve
Here is the control stage........
Old 26th March 2007, 01:53 PM   #5
N-Channel's Avatar
....And here is the power stage. As you can see, one TL494 is running at high frequency for the DC-DC converter, and the other TL494 is running at 120Hz for the DC-AC section.
Realize that you are asking with regards to the SG3525, but this schematic should be adaptable from the '494 to the '3525.
Old 26th March 2007, 02:04 PM   #6
audiovista is offline audiovista  Serbia
I can translate the text. Let me know if you found another solution and how urgent it is (next few days are hectic for me).
Long time ago I designed almost identical circuit, with the same chip. The SG3525 is very easy to work with, circuit is simple and reliable.
Boris
Old 26th March 2007, 02:40 PM   #7
m-tech is offline m-tech  Serbia
There is no Yugoslavia any more.
Article is written in Serbian language.
The circuit is very simple.
P1 is for adjusting output voltage.
P2 is for adjusting output frequency.
Output of the inverter is between 0 and 300V connection on the transformer ( in this case SD pin on SG3525 is pulled high ).
Connection 0-220 is for Charging battery mode ( SD pin on SG3525 must be pulled down to ground, for shutting down inverter ).
I hope you understand me.
Old 26th March 2007, 03:26 PM   #8
Hey m-tech...you have the wrong flag under the user name, check out mine
Old 26th March 2007, 09:26 PM   #9
Old 29th March 2007, 03:31 PM   #10
Hello!!!!
Thx for helping me......
N-Channel........u have done a gr8 job....but plz dont mind i cant understand that ckt as it is very difficult and also i have no time to design this kind of ckt....and as i said plz dont mind coz if i m not using it ....may b some other person will try it...
audiovista......as u said that u cant translate the text......plz do it ASAP coz i badly need it.....that site has discription [ moderators plz understand this situation i m not advertising the site....i m just trying get help ]
m-tech......thx for providing the information.....i m slodering the ckt now as Orcad doesnt provide the simulation [if u know how can i simulate plz tell me] then i'll findout whether u r right/wrong...then tell u....
Thx all of u.....plz read ur individual msgs....n reply then
XPIKON
SG3525 for InverterHide this!Advertise here!
SG3525 problem ifrythings Power Supplies 36 12th December 2013 07:30 AM
sync of SG3525 Trevorferns Power Supplies 9 29th March 2013 08:47 AM
messed up with SG3525 inverter jash2008 Car Audio 4 16th December 2008 01:42 PM
spike from SG3525 jegandren Power Supplies 7 13th September 2008 04:23 PM
SG3525 loop lorenzo_cy Power Supplies 5 1st April 2007 05:39 AM
