Power Supply Resevoir Size
Old 29th September 2012, 11:33 AM   #1331
R.I.P.
I would expect very little difference.
Why?
Because the capacitors are supplying the current. The current demand remains the same so the capacitance should substantially stay the same.
The difference the transformer makes can only be really be effective when the diodes are conducting and that is during the cap re-charge period, of the order of 10% duty cycle. During the other 90% the transformer is very effectively disconnected.
regards Andrew T.
Old 29th September 2012, 12:24 PM   #1332
DF96 is offline DF96  England
The size of the transformer, like the size of the capacitor, becomes important as you sail closer to the wind, where the difference between the off-load supply rail voltage and the minimum required rail voltage gets small. Elsewhere, a too small transformer will simply get too hot on continuous peak load but maybe not with real music. There will be small 'crossover' region where to some extent capacitor size and transformer size can compensate for each other - commercial designs, for cost reasons, may sit in this region but DIY need not.
PSUD2 simulations tell me transformer resistance plays a much smaller role than I expected. I am still thinking about why this is so. Part of it could be that resistance flattens and spreads the charging pulse, and this means less diode drop so the extra resistance is partially compensated for.
Old 29th September 2012, 03:21 PM   #1333
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Me too.
However, Tom already showed that a transformer close to the verge of slightly to small makes a gigantic leap in required capacitance. That doesn't meet linear expectations.
My point:
I'd like to see a spreadsheet where one could enter capacitance and amplifier wattage and then the spreadsheet generates transformer VA as the answer.
Wouldn't that be great?
It is highly applicable because we are shopping for both transformers and capacitors.
Indeed, that is noteworthy. Thank you!
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 29th September 2012, 04:02 PM   #1334
Slight snag with that. Transformer VA measures how much heat is generated and how well the transformer gets rid of heat. It is only the former (secondary effective series resistance) which affects the calculations we are doing here. VA is used as a proxy for resistance, but what is actually needed is transformer regulation (e.g. 5% for fulll power) - from that Ohm's Law gives the series resistance. So the spreadsheet needs either Rs, or VA and regulation. (Typically, regulation varies somewhat with VA, getting better at higher VA.)
Further snag: the relationship between Rs and PSU output voltage is non-linear and mathematically messy. However, if Rs is sufficiently small then it can be treated as zero or somewhat lost in the diode resistance. For larger Rs and sufficiently large capacitance I have found that a rough approximation is that DC voltage droop is proportional to (current x Rs) to the power 2/3.
Old 29th September 2012, 09:42 PM   #1335
gootee is offline gootee  United States
Originally Posted by danielwritesbac View Post
Tom? Howabout 28+28vac 144va transformer, 160va transformer, 200va transformer as comparison points? That would be really fascinating for comparing what happens with the needed capacitance.
With what load resistance and output power rating(s)?
Old 30th September 2012, 12:07 AM   #1336
8 ohm speaker, and amp wattage sized so that one or more transformers is too small, but not all of them too small.
Old 30th September 2012, 03:03 AM   #1337
OK... The 28VAC is RMS so that would give 39.6 V peak, which could give about 37.6 V DC, which would give a maximum peak output voltage across the load of about 34.6 Volts, for a maximum sinusoidal output power of 34.6/8 = 149.6 Watts RMS.
I'll probably try 100 Watts output power and might adjust it up or down from there.
It would be interesting to sweep the output power, for each VA rating, and see where the minimum capacitance starts to rise disproportionately (if it does). But I wouldn't want to have to calibrate the output's level and DC offset for each step in the sweep. Maybe I can figure something out, for that.
Old 30th September 2012, 04:02 AM   #1338
OK, I erred in the max output power calculation, using peak voltage instead of RMS.
The 34.6V peak output voltage would be 34.6/sqrt(2) = 24.5 V RMS so the estimated theoretical maximum RMS output power should be about 75 Watts.
Old 30th September 2012, 05:40 AM   #1339
All,
I have played with AndrewT's transformer parameters. I have made per-unitized (scalable) spice transformer components with them. I have run simulations of at least two of the previous cases, with them, to compare to the original transformer model.
Results show that the new model does not let the rails sag nearly as much as the original model.
For a 28.28 V square wave into 8 Ohms, with a 44 VRMS 240VA 60 Hz secondary powering each rail, the absolute minimum reservoir capacitance only went from 770 uF (using old model) to 630 uF (using new model).
But for a 40 V square wave into 8 Ohms, with a 44 VRMS 240VA 60 Hz secondary powering each rail, the absolute minimum reservoir capacitance went from 6650 uF to 1950 uF. But with the new model the point at which the square wave is down to 0.01 % distortion is within 1000 uF of where it was with the old model.
All data is attached in an xls spreadsheet file.
Tom
So, if we NOW look back and compare to the calculation method that was outlined in post 1246, i.e. at Power Supply Resevoir Size , we can see that for the 50W and 100W cases, where simulation with the new-and-improved transformer model gave minimum C values of 630 uF and 1950 uF, the calculations predicted 705 uF and 1650 uF.
One is high by a factor of about 1.12 and one is low by a factor of about 0.85. But unless you use your system at its maximum output power rating, the predicted values should prevent gross clipping distortion.
I would probably want to multiply the predicted C value by 3x, to get the distortion metric down into the 0.01% region.
The equation derived in the post linked-to above is:
C_min ≥ i_load / (2 ∙ f ∙ (Vc_pk - Vout_pk - Vamp_min))
where we already know the desired max power and the nominal load resistance and the candidate transformer secondary output voltage, enabling us to calculate all of the terms in the equation above:
i_load_rms_max = √(Power_rms_max / R_load)
Vout_rms_max = √(Power_rms_max ∙ R_load)
Vout_pk = (√2)(√(Power_rms_max ∙ R_load))
Vc_pk = (Vrms_secondary x 1.414) - 1.4
Vamp_min = 3 or so (Min Vce plus worst-case voltage across the 0.22-Ohm R)
f = line frequency, e.g. 60 Hz or 50 Hz
Old 30th September 2012, 09:10 AM   #1340
R.I.P.
post1338 supersedes.
OK... The 28VAC is RMS so that would give 39.6 V peak, which could give about 37.6 V DC, which would give a maximum peak output voltage across the load of about 34.6 Volts, for a maximum sinusoidal output power of 34.6/8 = 149.6 Watts RMS............
Here we go again.
There is something wrong with the sim if you are predicting 100W into 8r0 from a PSU that is connected to a 28+28Vac transformer.
That 100W into 8r0 typically needs a 35+35Vac transformer.
regards Andrew T.
Power Supply Resevoir SizeHide this!Advertise here!
How do you calculate choke size in a power supply? Burnedfingers Power Supplies 28 19th July 2017 08:03 AM
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 04:12 PM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 02:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 05:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 6th December 2007 11:50 PM
