#1221 |
Daniel @ #1213
you are right re. the cap ESR, but as Frank points out above, ESR varies strongly with time, temperature and sock colour (among other factors). its a commonly used trick, but because of this variation its not a very robust one. look at an electrolytic ESR for example - good cap data sheets specify ESR at 20C and at -10C - this is because ESR rises sharply at low temperatures. this can (and does) cause stability and even startup problems with regulators that rely on the ESR*C zero for stability. A much more robust, predictable method is to use very low ESR caps, then add your own series resistor to get the desired zero/damping. pay close attention to peak pulse power dissipation though - not all resistors are created equal. This specifically includes wire-wound resistors - quality WW resistors pack the wound mandrel with potting material before placing it in the ceramic body & encapsulating it; cheap nasty WW resistors drop the wound mandrel into the ceramic body and cover over the hole. the result is plenty of air around the resistive element, which hugely decreases its peak power handling capability - I have seen pretty orange flashes of light coming from the resistive element when given a good thump, before the resistor fails. Vitrohm for example dont do this, but all the WW resistors I can get from hobbyist stores in NZ are made like this. you can check a WW resistor by smashing it open with a hammer, providing hours of entertainment and making a mess ![]() there are also some seriously good SMT resistors with astonishing peak pulse power ratings - Panasonic ERJP and Vishay CRCW-HP are awesome. Last edited by Terry Given; 17th September 2012 at 01:12 AM. |
#1222 | |
The "uF per Amp" for 1X the rated output power (sine), instead of 2X the rated output power (square), would be √2 times the ones I gave using the 2X cases. So instead of 2500uF/Amp when considering the max load current at 2X the rated power, it would be about 3500uF/Amp. Or, you could go as low as 1600-1800uF/Amp (using load current at 2X rated power) which translates to 2200-2500 uF/Amp, using the load current for the rated max output power. The output currents for the 25W, 50W, 75W, and 100W 8-Ohm cases would be √(P/R) = 1.77A, 2.5A, 3A, and 3.5A. Using 2200 uF/A, their reservoir capacitances could be 3900uF, 5500uF, 6600uF, and 7700uF, which should give roughly 15% worst-case ripple and 0.0075% Avg RMS Error for a square wave at 25 Hz, at 2X the rated output power (i.e. w/same peak output voltage as a sine at 1X the rated output power). Using 3500 uF/A, their reservoir capacitances could be 6200uF, 8750uF, 10500uF, and 12250uF, which should give roughly 10% worst-case ripple and 0.005% to 0.0055% Avg RMS Error for a square wave at 25 Hz, at 2X the rated output power (i.e. w/same peak output voltage as a sine at 1X the rated output power). For output power ratings of less than 100 Watts, less capacitance could be used, but the ripple and distortion percentages would then be higher. Using the same "uF per Amp" factor keeps the ripple percentage and the output distortion percentage about the same, for any output power rating, unless the transformer is too small. But again, for the 100W case, if the transformer is rated at less than 44-0-44 Volts, or less than 480 VA (240 VA per secondary), then 2200-2500 uF per Amp might not be sufficient. (But, assuming the transformer ratings were "reasonable", it probably would be sufficient, for most people, most of the time, unless they want to run the amp at its max rated power with a guarantee of absolutely zero clipping.) I will try to run the 100 Watt case with a series of transformer sizes, to see what effects that will have. It seems that choosing the transformer VA and Vrms ratings is at least as important as choosing the total reservoir capacitance. It would be nice to have a simple formula relating Vrms, VA, Pout, Rload, and Creservoir, that would also assume at least a bare minimum of 3V to 6V for the amplifier, between the bottom of the worst-case rail dip voltage and the top (peak output voltage) of the load. Maybe someone can figure out (or already knows) how to add the VA and Vrms limitations to what we already have for Pout, Rload, and Cres. Cheers, Tom Last edited by gootee; 17th September 2012 at 02:45 AM. |
#1223 | |
. Looking forward to your layout
www.harrisonaudiolabs.com |
#1224 | |
. So as not to grow old too fast, do many activities, make many friends , take it easy
#1225 |
Heres the tickle
We have many measurements we can make including TIM, PSRR, THD, Slew rate, Dumping, square wave tests etc. However the question remains whether we interpret their importance correctly and whether they are actually valid for what we are trying to achieve. Lets have fun. We have the formulas, are they valid ? What do the speakers and ears think ?
#1226 | |||
Thanks!! Very effective and informative!
EDIT: The length of the power supply interlink cable also has an effect. Shortest possible = dullest possible with most bass Very long = clearest possible with least bass. However, This is not a lot different than changing the size of the amp board's decoupling caps, smaller for a combination of more forwards and clearer -or- larger for a combination of duller and more laid back. Tuning this size is a really common sport with chip amplifiers. . . AND, as previously mentioned, results on ideal amp board decoupling cap size all differ somewhat depending on power supply interlink/umbilical cable length. Quote:
These 3v ingan really go berserk in the presence of noise while there's no serious overheat with cleaner power. Well, there's a lot nicer uses for this instead of burning down RV's. For example, bleeder resistors that attack more noise than clean power (or attacking almost only noise if adding a stout zener), or so much like riding lawnmower races, the t-amp loudness wars in my signature below.
♦ Tools & Guides ♦ ClipNipper headroom boost ♦ Parallel LM1875 pt2pt ♦ Easy parallel TDA7293 board ♦ TDA7294 pt2pt ♦ My post has opinion. Last edited by danielwritesbac; 17th September 2012 at 06:45 AM. |
#1227 |
Daniel,
stick the resistor in series with the low-ESR capacitor ----[external resistor]-----[capacitor with low ESR]---- gives RC "damper" with C = C_capacitor, R = R_external + ESR the idea is to use low ESR caps so that ESR*(temperature factor)*(time factor)*(batch factor)*(WTF factor) is small compared to R_external. that way even when ESR changes a lot, the total resistance doesnt change much. example: 1uF + 4R. we could use a JPCON 1uF 50V cap with ESR = 3.8R and that would sort of work. but at -10C the ESR will be at least 15R (probably higher - these are lousy caps so I imagine the ESR-vs-temperature curve is a lot worse than a Rubycon ZLH, which increases 4x). And as the cap ages ESR will go up too. god knows what the cap-to-cap variation is, but I betcha its not great this means damping depends strongly on actual cap, temperature & time. yuck. quadrupling the resistor is almost certain to have a noticeable (not in a good way) effect. but if you use a 1uF MKP cap with ESR ~ 10mOhm + 3R9 resistor, then even if the cap ESR changes by a factor of 10 (+900%) the damping resistance goes from 3R91 to 4R = +2.3% |
#1228 | |
So I just pop in now and again to see the latest. The above has me confused. I use a 35+35Vac transformer for a 100W into 8r0 amplifier. Why the reference to 44-0-44 Volts transformer? Is that a peak of the AC waveform? or the AC voltage after applying the transformer regulation, or taken literally as a 44Vac-0-44Vac transformer giving supply rails when powering a quiescent output stage of very approximately +-60Vdc. I am lost and this may be due to not following the Thread in detail. |
#1229 |
Andrew,
is it possible for you to measure & post the parameters of the 35+35Vac transformer you use? (using the technique Tom gave about elleventy-seven posts ago, reposted here for convenience) I'd like to Per-Unitise them & compare with Toms Toroid - IMO the secondary resistance is very high, as is the secondary leakage. which leads of course to bags of LF droop. |
#1230 |
Hey Andrew, you might like to have a look at Tom's new spreadsheet
http://www.diyaudio.com/forums/attac...-copy.xlsx.txt (save and then rename/remove the ".txt" so that the file name reads PSU_Square_Load_Data_PU2.xlsx and then a spreadsheet can open it)
♦ Tools & Guides ♦ ClipNipper headroom boost ♦ Parallel LM1875 pt2pt ♦ Easy parallel TDA7293 board ♦ TDA7294 pt2pt ♦ My post has opinion. Last edited by danielwritesbac; 17th September 2012 at 09:04 AM. |
| Valve power supply - How to size transformer? | SanderW | Power Supplies | 25 | 4th January 2013 04:12 PM |
| How do you calculate choke size in a power supply? | Original Burnedfingers | Tubes / Valves | 25 | 5th January 2012 12:23 AM |
| power supply bypass cap size | BigE | Power Supplies | 11 | 5th July 2011 02:59 PM |
| Power Supply Case Size | diymixer | Power Supplies | 1 | 10th October 2010 05:47 AM |
| What size power supply should I get for repair work? | spooney | Car Audio | 3 | 6th December 2007 11:50 PM |
