Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th February 2010, 06:32 PM   #781
fff0 is offline fff0  Singapore
Originally Posted by Salas View Post
Had in mind about 9W in total do dissipate (36Vout) and just had that sink. Its not that big, the board on it on the photo is quite small.
I underestimate the heat dissipated by a shunt regulator. I suppose the proto board is 3 by 2 inches?
Old 19th February 2010, 06:39 PM   #782
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Exactly. Or 7.5x5cm.
Old 19th February 2010, 07:03 PM   #783
1 more question: Is the calculated wattage applicable to both M1 & M2? Meaning: at any time, both mosfet is going to output around 3.4w(taking Andrew's calculation) and not at 3.4w each, right?
Old 19th February 2010, 07:22 PM   #784
Salas's Avatar
For the CCS Mosfet the dissipation will be any chosen (Vin-Vout)*Iccs. For the shunt Mosfet will be Vout*(Iccs-Iload).
Old 20th February 2010, 12:02 PM   #785
if you want an output of 36Vdc and a CCS current of 200mA, then the minimum input voltage will be 36+10V=46Vdc.
The maximum to minimum voltage range of the mains is ~12%
46 * 1.12 = 51.5 Call it 52Vdc.
The maximum total dissipation is ~52Vdc * 200mA = 10.4W, plus a bit to power the CCS LED string.
The output load + CCS FET + Shunt FET must dissipate all this power.
If the output is shorted the CCS FET has to dissipate 10.4W.
If the output is open circuit then use the formulae that Salas gave.
regards Andrew T.
Old 21st February 2010, 05:46 PM   #786
Thanks Andrew for the in depth explaination.
Is it useful to use the following arrangement: 20Vdc->7815->Iko regulator->5v, adding on the total regulation. Have I missed out any other problem that maybe induced during the process?
Salas, are you able to take any noise figure supression of Iko's regulator?
Old 21st February 2010, 08:37 PM   #787
Salas's Avatar
Beyond a comparison on the total noise floor of the same audio MC Riaa circuit with my V1.0 and Iko's V2.0 5d that I already did and saw no difference, I don't have a better straight way, I lack lab grade equipment and lab methods experience.
Old 22nd February 2010, 09:52 PM   #788
ikoflexer's Avatar
Default revision 5k
Here we go, another update.
I've been very busy running experiments after Salas let me know about his tests. One thing that got to bother me more was the drift of current/voltage with temperature. So I made a minor change to the CCS to make it more stable. While I was at it I also made a change to increase the phase margin to a value which in theory predicts unconditional stability. All this while maintaining good psrr and low output impedance.
As much as I didn't want to introduce another circuit, especially that I had designed the PCB already, I had to do it, so here it is, below, with some simulated curves. There are more things to say about the circuit, which I'll probably include in the how to document, or answer questions as they come. The output impedance plot changes at low frequency with the value of the Vref bypass capacitor, C2. It's not really practical to have a large value there (the plot shows a 1000uF Zout) because it takes a long time to charge it due to the lowish current that passes through J3. Note the J201 below Q3. One can use other jfets there, 2n3819, 2sk170, etc. It's not a fussy position, but the Idss current is important, so whatever you use to replace J201 make sure Q3 can dissipate the power (voltage across it times Idss). The mini-CCS now employs a J310 on top of the 2sk170, so people won't complain any longer about the proper way of doing it (meaning the top jfet should have higher pinch-off voltage and Idss than the lower mosfet, and the current through should be about 15-30% of Idss).
J4 should have Idss from 6 to 9mA.
Just like before, other mosfets can be used. For higher voltages somethings else should be used for Q3, perhaps a BC550 or equivalent. The way it's presented here should work fine up to 20 something volts out. As for the current limit, it's set via R1. R1 is rougly equal to the sum of the forward voltage of the LED plus the Vbe of Q4, divided by the current limit desired. For very high current loads the circuit needs to be changed a bit, and I'll post later the modifications.
NB: Q1 and Q2 are MPSH81, Q3 and Q4 are 2N5088, M1 and M2 are IRFBC40
I will re-design the PCB as soon as possible if people are still interested.
This circuit was tested in reality for stability and noise for the last few days. The only change is that I've used a 2sk170 for J5 but will test again tonight with a J201, which is easier to find.
Better ripple rejection than before, and increased CCS stability.
Sub-milliOhm output impedance in the audio range and a bit beyond.
Theoretically the phase margin is about 66 degrees, which should qualify the design as stable. Note that no compensation capacitors are used on the cascode bjts Q1 and Q2.
Old 22nd February 2010, 10:07 PM   #789
Telstar is offline Telstar  Italy
Definitely interested.
But please as long as you are changing it, make the new pcb in a way where it is easy to parallel (at least 2) the critical mosfets in high-current applications.
The response of the inner ear extends to at least 200khz - Dr W. Tempest
Old 22nd February 2010, 10:26 PM   #790
Ikoflexer,
Good one! So Q3 is now connected to the sensor? Negative rail, please.
Bill
The simplistic Salas low voltage shunt regulator ikoflexer Power Supplies 4802 11th February 2012 01:16 AM
Tube for a shunt voltage regulator jarthel Tubes / Valves 14 26th October 2006 05:19 AM
Page generated in 0.97643 seconds (12.61% PHP - 87.39% MySQL) with 11 queries
