The simplistic Salas low voltage shunt regulator
Old 4th June 2009, 07:34 AM   #331
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Originally posted by Salas
Keep in mind that the very low output impedance blends stages and channels less, so you may use not that many, especially when utilizing local RC decoupling on your circuits.
My guess is, with this low output-impedance the impedance of the wiring from reg to the load(s) will dominate the picture.
Do we really need RC-coupling if we star-wire not only the grounds, but the V+/V- lines as well? Doesn't RC-coupling kill the super low impedance from the viewpoint of the load?
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 4th June 2009, 08:32 AM   #332
jameshillj is offline jameshillj  Australia
Yeah Rudi,
I've seen some of your designs and posts - I'd guess this sort of cct would make you smile a bit - simple and it works!
I like simple ccts, myself - they match the simple brain here!
The corrected layout is a bit different and adding a few mm for larger tracks/ donuts/ options - a few days.
The dual version with included CMx is coming together rather nicely - having trouble sourcing the right fets for the CT rectifier sytem - on hold for
Working out the testing "protocols" and it looks like a plug in Module to change the diode string for the R2/ Q2 option - we already have a zener plug/socket for different voltages - the change in the R1 for different currents is a pain - haven't sorted that one yet.
Another concern was using the same heatsink for different current/voltages that may "skew" the results a bit, as the component temp changes. I wouldn't mind another opinion about this .....
Currently, I'm thinking about these tests - advice requested.
* +15v @ Icc of 90ma (both Leds and R2/Q2 versions - load of 10ma and 40ma - have the cct values)
* +15V @ Icc - 250ma (load 10ma and 100ma - have cct values)
* +24v @ Icc - 550ma ( load 250ma, for my headamp!)
* + 44v @ 200ma (the Cygnus X version - Naim front end).
Tests to have input ripple 50mv (maybe sawtooth, not sine).
Depending on the time available, testing for the usual impedance/freq, residual ripple/freq on output, step function (perhaps that test cct) - if it's similar to Iko's SIM tests, can compare these results.
Than mentioned using a sawtooth input (ripple) instead of the usual sine - I think it's a more relevant test but, it will probably give different results - again, advice requested.
I haven't confirmed just how much time is available yet so much of this may not be possible - however, just planning stage for this.
Old 4th June 2009, 12:20 PM   #333
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Rüdiger
Given that you use short and thick star wiring both for +V and earth (have tested this, its audibly better for dynamics and resolution), the local decoupling strategy has more to do with the PSRR of the most sensitive stages. Its mostly dependent on using a big low ESR cap locally if needed, and the current draw of stages supplied commonly. Not a straightforward answer. I determine the effectiveness of local decoupling by running FFT and watching the noise floor under 500Hz, with and without it. If its negligible, I avoid it. Also, under a threshold, I don't think that we listen directly to the interaction of impedance, but if some characteristics are excellent in a reg, its an indication of its unflappability under complex interactions with stages and thick musical signals, that is audible in the end. I use dense choral music with full tilt orchestra to examine such. Like Mythodea.
Old 4th June 2009, 01:24 PM   #334
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
For regulators on separate boards I would strongly recommend CAT 6 twisted pairs for connection.
low HF impedance, low pick-up, low radiation.
Old 5th June 2009, 09:10 PM   #335
iko is offline iko  Canada
iko's Avatar
Default high bandwidth and stability
In the last little while there were several shunt regulator designs being worked on and I've seen people mention stability, but not many details about it. So lately I've been analyzing the stability of v1 and v2c, these two versions being the only two I am really interested at the moment. All analysis was done on the simulator. For v1 (R6 mod, LED bias) it seems that the circuit as is happens to be at the edge of stability. The calculated phase margin at unity gain was about 1 degree; to be somewhat sure that the circuit is stable (taking real world environment and component variations) designers try to get a phase margin of about 45 degrees. My personal experience was that there were times when I built v1 and it worked right away, stable, and then there were times when it oscillated, so the simulated stability analysis is in some correlation to reality. Considering various differences between components in the real world, this would happen. An significant increase in phase margin can be had by a small capacitor on C-B pins of the NPN driver transistor. In simulation an 18pF capacitor would bring the phase margin to 35 degree. This does not mean that you should use this value. I would take this result to mean that, all else being equal, if you build v1 and it oscillates, the first thing to try would be a small cap on the C-B pins of the BC550B. I would step up the value if still oscillating, up to about 300pF. If it still oscillates then it almost surely a different problem.
All the simulated outstanding output impedance results I have shown so far for v2c (the two stage amplifier with a cascode in the first stage) are without a significant frequency compensation. The results would look a bit less stellar with compensation. This is a very funny game played here, the more loop gain you have across the frequency spectrum, the more inherently unstable the circuit will become (the phase lags at high frequency and you get into negative phase margin). When you try to compensate (various ways) the loop gain decreases at high frequency and behold, the output impedance goes down big time. I realized that in order to maintain high loop gain AND stability one should be serious about wide bandwidth design. As far as I am concerned, for v2c, to make it keep its lower than v1 output impedance I could use bfrt92 and bfrp92 RF drivers with high frequency compensation (details left out). Is it worth it? For those who want to squeeze the very last bit of performance out of a circuit, perhaps. For most, you can be pretty sure that most people will not be able to do better then salas version 1. Am I 100% positive of all this? Nope. Please correct me if I'm wrong.
Any high speed amp designers around here to give some advice?
Old 5th June 2009, 09:33 PM   #336
Salas's Avatar
V1 has been made very many times since fall 2008 by many different people in different guises. It worked in all cases. Always with a Cout on board in the hundreds of uF.
Old 5th June 2009, 09:53 PM   #337
iko's Avatar
Then my analysis must be wrong. As long as it worked for people, I have no problem being wrong.
Old 5th June 2009, 10:02 PM   #338
Salas's Avatar
Its not necessarily wrong. The current source as a load brings the gm*load gain pretty high. I was worried for instability issues my self when we did that mod in the Riaa thread. In practice it worked for all people with gains in the highs, so no worries. The real components seem they can give a somewhat more margin than predicted, so if it works, its better to keep the gain up high. In a case (not reported yet) that there is persistent instability, the npn can be BC550B instead of C for instance, so to compromise the loop gain. Or use a comp cap between C,B of the driver, as you saw. Stacked ceramic I would suppose.
Old 6th June 2009, 12:45 AM   #339
Default higher speed version
My idea is to use smaller mosfets unless u really need to use big ones.
The version of the cct I posted here used zvp3306a's
perhaps for low current & low voltage applications this would be ok
http://www.diyaudio.com/forums/showt...93#post1825993
I think this would be faster
but might be wrong
just my idea
Old 6th June 2009, 01:31 AM   #340
but I think my simulations showed that is was faster.
are we still trusting simulations ?
hehe
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
