Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 9th February 2010, 03:49 AM   #151
Few is offline Few  United States
Henjo: Nice job! It looks very well put together. The voice coils came out very nicely. I'd love to see some frequency response measurements.
How readily available (and costly) is ferrofluid? That seems like it would really help keep the voice coil from rubbing on the magnets. I don't know if it would pool at the bottom of the gap under the influence of gravity, though.
Few
Old 9th February 2010, 04:00 AM   #152
tinitus is offline tinitus  Europe
I dont think theres any issue with having a magnet gap like say 5mm, with those strong neo magnets available
The ones I have been looking at lifts 60pound EACH, and there may be like 12 of them on each side of the gap, a total of 24 magnet on each speaker
24 magnet would lift close to 1500pounds
But to assemble it all without getting hurt badly could be a delicate operation
But I have plans fore that
But it could be exstremely dangerous if handeled carelessly
Old 9th February 2010, 07:13 AM   #153
koldby is offline koldby  Denmark
Very nice!!
How did you roll those very fine coils?
Keep up the good work and please keep us updated on your progress.
Anybody else who did a prototype?
Koldby
What is Home Theatre without good sound?
Old 10th February 2010, 12:11 AM   #154
Henjo Edel's Avatar
@ Koldby
Coils are hand wounded.
Every turn was glued on the paper with cyanoacrylate.
3 to 4 hours work, and a lot of patience
Here's a closer picture, just before sticking the two pieces of paper together.
Center distance of the coil 20mm, length 300mm, turns 16.
Henjo
Old 10th February 2010, 12:50 AM   #155
Fore what its worth, here the principle of "motor" design
One huge advantage is that you can use very strong magnets, without having any problems to keep them in place
Another big advantage is the narrow magnet gap, over a ribbons and planars
And you get two gaps with opposite polarisation, perfect fore the "voicecoil" having "two directions"
And you can make it underhung
And not to forget all the other stuff like sensitivity, huge bandwith, cheap materials, use of solid copper wire, etc
And probably close to indestructable
Henjo, how do you rate sensitivity of your proto ?
Old 10th February 2010, 09:17 PM   #156
mightym is offline mightym  United States
mightym's Avatar
Location: Checotah, Okrahoma former home of the Okra Fest
Originally Posted by tinitus View Post
I think the original Rubanoide has a thread to prevent sagging
I consider to use 2 strings in a "V"..."a henfoot", like men of the sea call it
I was thinking along similar lines. I have also been considering some silk cloth, doped like a spider, cut into a triangle, and corrugated while wet to allow the voice coil to run linear while the " suspension " stretches a controlled amount. Mounting one top and bottom.
John
BTW Henjo, Excellent looking work. Just how heavy is that paper? I've been considering Kraft paper, with a doping of Dammar lacquer.
Old 10th February 2010, 10:17 PM   #157
I dont think they are supposed to move that much
I certainly intend to use other means fore the dipole and BSC compensation
"Rubbing voicecoil" may not be the real issue
Im more concerned about instability causing small ressonaces
You might call it non linear motion
But the less it moves, the less to be concerned about
At least I think so, but actually not sure about it
Old 10th February 2010, 10:25 PM   #158
Henjo Edel's Avatar
The paper is 200 gr/m2.
I don't worry about sagging. I thought it was used to center the paper between the magnets. Because they are also at the lower end.
Henjo
Old 10th February 2010, 10:52 PM   #159
Joachim Gerhard's Avatar
Great and simple design ! i would love to see some measurements but radiation pattern may make that a bit complicated. Important is that it sounds good.
Old 10th February 2010, 11:46 PM   #160
Henjo Edel's Avatar
Here is a quick and dirty measurement. Uncalibrated microphone.
Graph isn't labeled. Steps of about 15 deg.
Yellow = 0 deg.
Green (light) = 90 deg
BTW magnets are ferrite class Y30BH.
Henjo
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Henjo Edel
Ribbon Bookshelf Speaker LineArray Multi-Way 2 6th June 2008 12:38 PM
What kind of laptop to analyze speaker ostie01 Multi-Way 2 27th December 2005 08:18 PM
New Ribbon Speaker Technology - Approach the perfect speaker? cocolino Planars & Exotics 49 16th January 2005 11:12 PM
What kind of speaker design is this? Keith TDI Multi-Way 8 25th March 2002 04:56 AM
Page generated in 0.08600 seconds (72.24% PHP - 27.76% MySQL) with 11 queries
