I love my 6V6 pre! I need something decent as backup when I make some changes to it.
I managed to get one channel to 2mV and the other to 5mV before the caps, could do better though. But I was afraid to leave without them. Do you think it' s safe to go without them?
I wouldnt try it without balanced(plus a minor modification.) 6V6 is wonderful. If using the BA3B as a preamp, you have to tune it carefully or it will add too much of its character(even at reduced distortion tuning) to the final package. It did not mate well to J2 or Funny^6 when used as standalone. Funny that it works best with a buffer on the output
off topic ( but who cares ) - which stacking arrangement you prefer with that AVC and - exactly in which configuration (preceding stage , next stage )
I use it at the output of my #26 pre. So far only tested at stock value of 20H but I want to try 3x3 at about 150H. The thing is too much hassle with all this wiring, but will do it some time soon.
Thanks Buzz. So was right not to use it without caps in single ended.
I will have a look at the BA3B thread also.
it works pretty well , as described here : AVC & Input Selector for Papa’s Koan M2 ; temporary case ? | Zen Mod Blog
even buffer-less , I like it much more then expensive TKD pot , which was previous solution
for now , this is most informative : :: View topic - play airgap of autoformer volume .
as soon I put buffer in there , will try .....
Any links to that?and I better not ask how it would work if output mosfets were replaced by another jfet pair
Any links to that?
tricky(difficult)
but easy to just post the schematics hope that is ok
May I ask you which TKD pot….?
even if that's similar , it isn't anything like BA3 FE
and I'm pretty sure that Juma didn't wrote it is
no, he did not
and I never said he did
probably accidental mistake on my part when I asked for such a design, and suddenly remembered these curcuits by Juma
they are probably from a thread about 'alternative' preamps for F5
and yes, they are off topic
please ignore
pretty important virtue of BA3 FE is lack of overall feedback , while both of these stages are more like F5 , with feedback connected in more common manner
and I suppose it is not possible to ... ehh ... I suppose better not ask
- BA-3 As Preamp
