Old 20th July 2012, 08:53 AM   #181
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally Posted by Melon Head View Post
Just leave it outside the case
best PSU is - no PSU
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 20th July 2012, 09:09 AM   #182
mindutis's Avatar
Does that lead to best amp - no amp? Click the image to open in full size.
Old 20th July 2012, 09:48 AM   #183
run the amp direct on the higt voltage mains 10.000V+
aleph P1.7 pre. F5 power amp. CDpro2(need DAC).
Vivaldi8 speakers
Old 20th July 2012, 11:19 AM   #184
www.audiohobby.com
How do I get a shirt?
Old 20th July 2012, 11:48 AM   #185
Originally Posted by Nelson Pass View Post
I often quote myself as I find it adds spice to my conversation.
Oh look! I found a couple of stills from the Amp Camp footage.
On the left, moderator Variac and on the right Jason, the founder of DIYAudio.
A group or a mosaic photo [if any] for the members of DIYAudio to E-meet the principals.
Old 20th July 2012, 10:37 PM   #186
LBHajdu is offline LBHajdu  United States
A thumbnail calculation sez that R12 = 100K would just about do it.
Does anybody know how that was calculated? The only thing I know (or think I know) is that without feedback (infinite value for R12) it would be a current source (tapped at the drain of Q1) which would be close to an infinite output resistance. But the gain would be too high and distortion would be much higher without a resistor on the source of Q1 which is also a kind of feedback. The gain is R12/R11.
Old 20th July 2012, 11:29 PM   #187
The one and only
Nelson Pass's Avatar
Yes, I do. I looked at my thumbnail and in it I saw a reflection of the resistor
bins, noting that I had 100K and 150K available. 150K seemed a bit high,
although you might want to try it.
Infinite R12 was measured in the article, and the gain was 23 dB.
Old 21st July 2012, 12:22 AM   #188
An ambitious bolded statement. Looking at the output node [opposed drains], and in the abscence of loop feedback, the resistance of the gain MOSFET[lower] is 9.5 Volts divided by the current flowing thru it; for example 1 Amp = 9.5 Ohms. Ditto for the MOSFET [upper] of its load = 9.5 Ohms too since it has identical static conditions. The load sees two resistors in parallel [one to ground and the other to AC ground at 19 VDC] each of which is 9.5 Ohms; for a net equivalent resistance of ~4.8 Ohms. It is high compared to the output impedance of a classical voltage source amp ~<0.1 Ohm. Loop feedback further lowers this 4.8 Ohm output Z, and extends power bandwidth. Distortion is low before loop feedback because the output stage is sliding/operating on a linear portion of its load line. Loop feedback linearizes further its operation.
Old 21st July 2012, 01:56 AM   #189
Oh I never thought of it that way (power devices as resistors). I guess it makes sense. I assume this implies output resistance and there by the damping factor also depends on the rail voltage and bias current. We could also assume without adding a resistor on the output we cannot make output Z higher than 4.8 ohm.
Would I be correct in assuming the reduction in output resistance can be calculated? If I look at the open loop gain of 23dB(14.1x) and the closed loop gain 14dB(5x) and if we take your 4.8 Ohm output Z. Then we could assume 14.1 * 4.8 / 23 = 2.9 Ohm output Z, which is fairly near to the stated output Z of Mr. Pass of 2.9 ohms calculated from the stated damping factor of 3 = 8ohm speaker / 2.6ohm DF.
So I guess my gain formula is wrong for values higher than the amps open loop gain. I forgot to take that into account. Woops. I blame high gain opamps.
Old 21st July 2012, 03:27 AM   #190
The one and only
Perhaps it's worth working through this a bit. The IRFP240 Mosfet has
a transconductance of about 2 when biased at 1 amp. This means that
2 amps of current flows for every volt of input at the Gate. So for our
purposes at the moment we will treat it as a Mosfet of infinitely high
transconductance with a Source resistor of 0.5 ohms. Since this circuit
does not supply an external resistance between the Source pin and ground,
that is all we need for a quick calculation.
If the output resistance (Plate resistance if this were a tube) was infinite,
then the gain into an 8 ohm load would be 8/0.5 = 16X, which is 24 dB.
But it's more complicated than that. The Mu follower current source on
top of the circuit also contributes to gain, adding maybe 5 dB. So now
we estimate that with infinite Drain resistance the gain is 29 dB, which is
28X.
OK so far?
But we actually experience 23 dB gain due to the finite Drain resistance(s)
and the contribution of the DC feedback loop. This 5 dB drop is a factor
of 0.56X, and is equivalent to our high Drain resistance example driving
8 X 0.56, which is 4.5 ohms.
So now we have an apparent Drain resistance which is equivalent to that
value which paralleled with 8 ohms gives us 4.5 ohms. That resistor is
close to 10 ohms.
Without the R12/R11 loop, the output impedance of the amplifier is 10
ohms. To get 6.5 ohms, apply a little over 3 dB of feedback to take the
gain down to about 20 dB. Probably my estimate of 100K was a little low
for R12.
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 27 7th December 2012 09:27 PM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
