Old 16th January 2013, 02:40 AM   #361
EUVL is offline EUVL  Europe
I did not feel criticized, just tried to explain why it is so.
Thanks for organising.
Patrick
xen-audio.com
Old 19th January 2013, 01:25 PM   #362
NicMac is offline NicMac  Italy
NicMac's Avatar
Default second channel under intensive care
6 DMM's would be nice
2SK1530/2SJ201 sales thread and FET list
Old 19th January 2013, 05:51 PM   #363
I see you are enjoying yourself.
Patrick
xen-audio.com
Old 19th January 2013, 07:18 PM   #364
NicMac's Avatar
Patrick
Of course
And tonight high-power fun with the PSU and my new-build 4 x 100W 4R dummy load
I may now have to lear to use my PicoScope
Old 19th January 2013, 07:41 PM   #365
My dummy load.
No heat sink required.
Patrick
xen-audio.com
Old 19th January 2013, 08:09 PM   #366
NicMac's Avatar
Without the heat-sink my dummy load would exceed the 200˚C rating of the aluminum clad resistors. With the sink I can however handle all 4 supply lines contemporarily and.......
it works a charm!
MS22 75004 thermistor and 3.15A slow-blow fuse. All OK.
5 mV ripple P2P (the scope say 100Hz! Why I thought I was living in a 50Hz country).
Rectification and caps does not generate much heat. The R's in the CRC get very warm, but nothing to worry about.
I have 15V over the load, but I expected a bit more. I hope it is sufficient also for the regulated supplies.
The transformers are not the ones from the GB. I got these from Canterbury windings and they were ordered before Patrick's increased the voltage specification. These have 15V/18A secondaries.
One happy builder
Nic
P.S. what is the easiest way to get traces from the PicoScope software to this forum?
Old 19th January 2013, 09:57 PM   #367
Horio is offline Horio  United States
Newbie
Horio's Avatar
Here is my 3-point matching rig, for measuring the JFET's.
I attached it to a heatsink I had laying around so it wouldn't move all over the place while I am matching the parts.
Old 19th January 2013, 11:08 PM   #368
NicMac's Avatar
Alexis,
the control PCB is between me and music so I kindly ask for your help in explaining the interface. I do have your schematics, but this is not entirely helpful as there are no pointers towards the amp schematics. To make it easy for you I have below listed the connections I would like you to indicate. Layman terms like "cathode side of left channel speaker relay", would be greatly appreciated. I am sure that several others would appreciate this information. Also a picture of the recommended jumpers for a default F5X would be greatly appreciated.
Nic
PCB left hand side:
LSP1/SENSE1
1: ??
2: ??
3: ??
4: ??
RSR2/ISR2
1: ??
2: ??
3: ??
4: ??
MR/TRP RST
1: ??
2: ??
3: ??
4: ??
PCB right hand side
SENSE2/LSP2
1: ??
2: ??
3: ??
4: ??
ISR1/RSR1
1: ??
2: ??
3: ??
4: ??
Old 20th January 2013, 02:33 AM   #369
Draw a rectified waveform and count the ripples.
Or do a simulation with LTSpice.
As they should.
No real concern.
The regulator still regulates as a cap multiplier even under 16V.
Screen shot.
Patrick
xen-audio.com
Old 20th January 2013, 09:46 AM   #370
ashaw is offline ashaw  Australia
Here is a connection set that is equivalent to EUVL's original Schematics.
LSP1/LSP2/ISR1/ISR2:
OFF - ON
SBY - OFF
SUD - ON
TRP - ON
RSR1/RSR2:
OFF - OFF
SBY - ON
SUD - ON
TRP - ON
Attached is a connection diagram put wire straps where the red lines are.
The connectors that this board is designed to use, if you mant them are 4 way Molex Microblade connectors.
Note:This Board has 24V relay outputs, If you want to use 12V relays as per EUVL for the protection shorts, you must wire them in series off board.
F5X -- the EUVL Approach EUVL Pass Labs 812 14th May 2013 02:25 PM
Potential EUVL F5X designed case user distribution check pchw Group Buys 1004 27th February 2013 03:32 PM
GB 2SK3497/2SJ618 for EUVL F5X or other projects pchw Group Buys 266 8th April 2012 06:05 PM
[B]PRP resistor group buy for the EUVL F5X build[/B] NicMac Group Buys 70 4th February 2012 04:20 PM
New Saburo Build thread Wha' DIYa know? Full Range 94 17th October 2010 04:49 PM
Copyright ©1999-2013 diyAudio
