Old 7th September 2003, 02:55 PM   #1
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Default modifying the D1 I/V stage (X?, CCS?)
Has anyone tried modifying the D1 I/V stage? I am wondering if it would sonically benefit if it was converted to an X type setup.
Also, what about using current sources?
Here is a picture of the stage from the service manual:
( http://www.passlabs.com/pdf/d1-srv-man.pdf )
Brian
Old 7th September 2003, 07:36 PM   #2
Algar_emi's Avatar
Default Single DAC use
Is it possible to use this I/V converter with just one DAC instead of two? For example by grounding the input of Q6. Will it work?
Old 7th September 2003, 07:44 PM   #3
The one and only
Nelson Pass's Avatar
You could remove Q6 and all the circuitry around it.
Old 7th September 2003, 07:47 PM   #4
jam is online now jam  United States
jam's Avatar
Brian,
You could get rid of R25 and R32 and replace them with 20ml current sources. With Mr.Pass's permission.
Jam
Old 7th September 2003, 09:13 PM   #5
BrianGT's Avatar
Will this output stage work well with the AD1955, which has stereo differential current output?
Brian
Old 7th September 2003, 09:49 PM   #6
BrianGT's Avatar
The datasheet for the AD1955 says:
"8.64 mA p-p Differential Output"
Do I need to change anything in the I/V stage to account for this difference, compared to the PCM63?
Brian
Old 8th September 2003, 01:42 AM   #7
The one and only
Check the DC output requirements of the chip, but otherwise,
ther answer is (should be) no problem.
Old 8th September 2003, 01:44 AM   #8
The one and only
In reference to the above schematic, I should point out that
the followers are not necessary for many applications, and you
could get by with the simple diff pair and the 1.5K resistors
(capacitively coupled, of course).
Old 8th September 2003, 07:12 AM   #9
Klaus is offline Klaus  Germany
Question conversion to 0,1mA DAC?
I have also released a question about converting the D1 stage, maybe in the wrong forum part, because just one answers has come so far...
The essence of the tread below is: how to use the 0,1mA I-output of TDA1547 with a changed D1-stage? My idea is the reducing of bias current to ca. 1mA and use of a smaller FET like e.g. 2SK389. Is there any mistake in this realization? Thanks for feedback!
modify D1 stage for 0.1mA DAC?
Klaus
Old 8th September 2003, 09:34 PM   #10
The one and only
It seems that current output DACs are designed to
ideally operate into virtual grounds.
As the transconductance of the JFET in question goes
down, more signal voltage will appear at the source,
and any dependence of signal quality vs output voltage
of the DAC will start showing up.
That said, I would expect it to work fine.
Could use help modifying a DJ mixer. DJNUBZ Solid State 3 18th April 2008 01:56 AM
CDM-12 Modifying poynton Digital Source 6 29th January 2007 07:26 AM
Modifying a power amp input stage to use 2SK389 Fanuc Solid State 4 27th August 2006 10:50 AM
modifying TM into MTM or TMM ultrachrome Multi-Way 3 12th May 2004 05:01 PM
Modifying Advent AW-820 clarkdv Multi-Way 2 24th April 2004 03:17 AM
Page generated in 0.09370 seconds (79.55% PHP - 20.45% MySQL) with 11 queries
